Results 1 to 10 of 10
09-30-2011 #1Registered User
- Nov 2004
- Gilbert, Arizona
- 50
Proform waterpump 67264 - not a CNC iron impeller
So, my Edelbrock waterpump on my 383 SBC finally gave up the ghost and it was time to order a new one. What to do? I looked at several different water pumps on Summitracing and found a Proform 67264 - with a description of ------
These Proform high-flow mechanical aluminum water pumps feature a CNC cast iron impeller spinning on heavy-duty ball bearings. The result is up to 40 percent more coolant flow, giving you real performance value for your dollar. They are available in a natural or polished finish.
This was the description by Summit and also Proform on their own webpage. I did a search, but there was not alot of info on the web about this pump, but there was one post that said it was supposed to be a CNC iron impeller like the description, but was a standard steel when they got it.
So, I called Summit's tech line and they called Proform tech services to confirm that it was a CNC impeller and they said it was. So, I ordered it.
Anyways.....I just got it today and opened it up and low and behold it was a standard steel impeller. Of course it was!!!!! What a waste of time that was. Got back on the line with Summit and told them this. They said they would have to contact Proform about this on Monday and I said don't bother, I will send it back and never order Proform stuff again, but I would like to order a Stewart Stage 2 water pump instead, which is what I should have done in the first place.
Just my 2 cents for anyone wondering about this waterpumpZ-28 has a built 383SBC. The heads are AFR 195 CNC ported with a 274 Solid Extreme Energy Cam. 1.6 rockers an Edelbrock RPM Air Gap intake and a 650 Holley carb. Turbo400 with a 10" ATI convertor 3200 Stall. 3.42 posi. Hotchkis springs/swaybar/UCA and Bilstein shocks.
09-30-2011 #2
