    Page 9 of 9 FirstFirst ... 4 5 6 7 8 9
    Results 161 to 174 of 174
    1. #161
      Aug 2011
      Burleson, TX
      Some progress made-ECM, TCM and Harness are in
      Got the Transmission Dip Stick mounting bracket cut off and welded in its new location to secure it to the head. Rattle canned it black and reinstalled.
      Click image for larger version.
      I have also connected the engine wiring harness including adding some heat shield on wires and cables near headers, installed headers for real and started some of the other wiring needed to get the engine running. I will have a temporary panel set up with the ECU, TCU, switches and possibly some of the relays installed on it since the body is still off. Final wiring will have proper weather pack connectors, heat shrink and the like. If all goes well I am aiming for mid November start up.
    2. #162
      Aug 2011
      Burleson, TX
      Finished prep work then got her running. Videos
      Made a temporary fire wall/dash, wired up the ignition, fans and fuel pump, put in an ample supply of various fluids and some fuel then lite her off.
    3. #163
      Oct 2007
      Awesome ken ! Could I ask you for a huge favor? Could you please get a photo of the coil wires on one or both sides? Specifically the colors to the large connector and to the front cylinder?
      You see I bought the same motor the coil bracket on the stock vale covers make it impossible to mess up they only go on one way. I put after market value covers on and I fear I may have mixed up the coins banks. I am right about at the same spot ready to fire it up and I am paranoid that I messed this up
      67 Camaro In progress
    4. #164
      Aug 2011
      Burleson, TX
      Quote Originally Posted by XLexusTech View Post
      XLexusTech is this what you are looking for?
      Driver Side Big Connector looks like Dark Grey, Dark Green, Brown and Pink in the front and Green, Red and Black in the back.
      Driver Side #1 Cylinder front looks like Pink, maybe a Dark Purple, Brown and Black.
      Name:  DS #1 Front Cylinder.jpg
      Passenger Side Big Connector looks like Brown, Blue, Purple and Orange in the front and Green, Red and Black in back.
      Passenger Side #2 Cylinder front looks like Orange, Red, Brown and Black.
      Name:  PS #2 Front Cylinder.jpg
    5. #165
      Oct 2007
      Yes sir thank you !
    6. #166
      Aug 2011
      Burleson, TX
      Yes sir thank you !
      You're welcome! Glad to help.
    7. #167
      Chesapeake, VA
      Very detailed, I like what you're doing. Thanks for sharing.
      Cars are meant to be driven.
      John B
    8. #168
      Aug 2011
      Burleson, TX
      Quote Originally Posted by jaybee View Post
      Thank you John. It is truly my pleasure as I have gained a wealth of knowledge from this and similar forums so I will not hesitate to help a fellow hot-rodder/motor-head.
    9. #169
      Aug 2011
      Burleson, TX
      Finally starting on the body
      Main floor plan issue is the passenger front where it appears the heater core went out and no one ever addressed getting all the coolant cleaned up and so the floor rusted out pretty bad here.
      Starting to fit the pan:
      Just about ready to start welding:
    10. #170
      Aug 2011
      Burleson, TX
      Winter is over
      Winter is over. Time to get back at it. Heat cycle the engine and continue cleaning off the undercoating on the body.
      Got most of the undercoating off the cabin area
      Name:  under cabin.jpg
      But still have the trunk area left
      Name:  under trunk.jpg
    11. #171
      Feb 2013
      Ken, we have nearly identical frames and I just got mine back from the sandblaster. Aside from the rear lower trailing arms, did you add gussets anywhere else?
    12. #172
      Oct 2015
      Car is looking great. Love all the powder coating and chassis mods. Only one mod I question is when you set back the engine mounts you tapped the frame instead of through bolting. The reason they are through bolted as the frame is not of sufficient thickness to tap threaded holes. I understand why you did it, just throwing it out there. I hope at a minimum you used fine thread.
    13. #173
      Aug 2011
      Burleson, TX
      No John I did not. However, I wish I had done a bar between the rails or some other tie-ins because this thing flexes something terrible when I jack up one corner at a time.
    14. #174
      Aug 2011
      Burleson, TX
      Quote Originally Posted by Alwhite00 View Post
      Alwhite00 - I would have never relied on the tapped hole only. I would have drilled that out and used bolt and nut fasteners as per the original. However, I eventually bought different adapter plates so I could move back to the original engine mount holes. so my transmission tunnel modification would be minimal. I hate body work!
    Tags for this Thread
