    Page 2 of 2 FirstFirst 1 2
    Results 21 to 37 of 37
    1. #21
      Fredericksburg, VA.
      I don't notice any smell but the drone can be a bit much especially since I'm running all 3" exhaust. Problem is that there is just not enough real estate to route 3" pipes over the axle. I was looking for side pipes early on but they are no longer offered. I also considered dumping the exhaust out in front of the rear wheels. Fact is the exhaust was intended to be temporary going on 7 years now.
      Steve Hayes
      "Dust Off"
      68 Camaro
    2. #22
      Aug 2017
      SC
      Thanks for the response Steve.
      Daniel
    3. #23
      Oct 2018
      San Jose, CA
      I added some 12” extensions and downturns to route the exhaust out from under the car better. I also have real estate issues with the fuel system on my car built by previous owner. Just this extra section made a huge difference in the sound. It’s not bad at all. This is a 2.5” Pypes with a crossover.
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
    4. #24
      May 2018
      Out of curiosity, what offset/backspacing are you running on the wheels? And is that rear end still a 60in track width? Trying to get about the same wheel fittament as what you have but I'm fabricating in a 64.9in rear end, so trying to get a decent basis of what I might be able to pull off without doing crazy work to the rear wheel arches.
      Love the build, one of my favorite camaros I've seen.
      T.O.
      1967 Camaro - "Herja"
    5. #25
      Apr 2019
      Scotland
      Country Flag: Scotland
      Love the stance on this car.. low and aggressive!
    6. #26
      Mar 2013
      Country Flag: Belgium
      I see you got the total control rear coilover suspension.
      What is your pinion angle on the rearend?
      Got the same kit for my cougar and have a pinion angle of 2.6, upper control arms at the shortest lenght possible..still acceptable but was just wondering what yours was.
      Also wondering how it is handling on your car?
      Got the same rearend from moser aswell.
      Great looking car you have!
    7. #27
      Saying your pinion angle is 2.6° is meaningless without a reference point. Is it relative to the earth? Is the chassis level? Is the angle relative to the chassis?
      Need more information.
    8. #28
      Mar 2013
      This is measured when the car is standing on its wheels.
      Still need to measure the angle of the transmission.
    9. #29
      Quote Originally Posted by 70CougarXr7 View Post
      Again, that's not relevant.
      If you are trying to determine the proper pinion angle, what you're actually interested in is measuring the u joint operating angles. The operating angles are the angles of misalignment between the drive shaft and the transmission output shaft (front operating angle) and the pinion gear (rear operating angle).
      For smooth high-speed operation you want the front and rear operating angles to be equal and opposite and as small as possible, but not zero. They should definitely be less than 3°.
      So in addition to measuring the pinion angle and the transmission angle, you need to measure the driveshaft angle, be cause it is your reference.
    10. #30
      Mar 2013
      Apologies for hijacking this thread.
      In the progress of measuring the lenght for the new driveshaft, once i have that and installed the new one i will measure it.
      Just always thought you could never exceed the 3degrees on the rearend itself...thanks for the explanation!
    11. #31
      Fredericksburg, VA.
      Well the center section started leaking gear oil so it had to come out to fix the leak. While it was out I decided to install an oil pump and plumb in a cooler. Here is a pic of the center section with the pump installed ready to go back in the rear end housing. This is a surplus NASCAR center section which was already machined to accept the pump. All that was necessary to install the pump was to have the pump drive hex machined into the end of the pinion gear.
      Steve Hayes
      "Dust Off"
      68 Camaro
    12. #32
      May 2013
      Colton Ca.
      I bought the same surplus nascar center section for my camaro as well. Im in the process of assembly of my camaro and haven't decided where I was going to put the cooler for the rear end. Im curious as to what you'll come up with.
      Ahmad B.
    13. #33
      Mar 2015
      JDMan did you go with a different set of rear shocks. By the looks of it i have the same rear kit but I cant get my car that low. My car sets about 1.5 inches off the top of the tire with my shock adjusters turned all the way down.
    14. #34
      Nov 2014
      I believe that in previous post/thread, he noted that he changed shocks. We have the same chassisworks setup with 200lb/in springs and swapped to 130lb springs. Greatly improved the ride and weight transfer when leaving from a dead stop (ie drag racing). Also, it lowered the car considerably and we have been able to add pre-load as the springs settle.
      Name:  camaro new springs tucked.jpeg
    15. #35
      Fredericksburg, VA.
      Quote Originally Posted by KCR View Post
      The short answer is Yes. One of the problems with buying suspension parts from different manufacturers is that you end up with some non-matching components that you have to make happy. The coil-over shocks were one of the areas I really struggled with and no matter what I did they just were not happy working together. The front DSE shocks were non-adjustable and the rear Vari-shocks were double adjustable. No matter what I did I could not get the suspension to work the way it needed to. In addition, the rear coil-overs were simply too long to get my desired ride height. I finally just got tired of messing with what I had and scrapped both front and rear coil-overs and replaced them with four AFCO double adjustable shocks. I went with four inch stroke shocks front and rear in order to get the shock in the center of the stroke at ride height. Once the shocks were in place and I was regularly driving on track it became obvious that the springs were far too soft. The last major suspension change was to up the spring rates from 600lb to 800lb front and 200lb to 300lb rear. I'm pretty happy with the way the car handles now even with the 800lb springs the street ride is surprisingly smooth and with a quick shock adjustment it's ready for the track. I have had people ask why I went with AFCO coil-overs and it is simply because I have a circle track background and AFCO is a major player in circle track racing. In addition, AFCO recently entered the Pro-Touring segment by offering specific a line of specifically tuned shocks for just for us at very reasonable prices. Finally, Matt at MCB is an AFCO dealer and can make you a great deal on them.
      Steve Hayes
      "Dust Off"
      68 Camaro
    16. #36
      Fredericksburg, VA.
      I was contacted by a writer from HotRod online who wanted to do a feature on Dust Off so I worked with him for a few weeks and he recently published the article. You can read it here.
      https://www.hotrodhotline.com/steves-68-chevy-camaro-ss
      Steve Hayes
      "Dust Off"
      68 Camaro
    17. #37
      Jonesboro, Arkansas
      Congrats Steve! Well deserved and a very nice car..
      Carl Wilson
