    Page 7 of 7 FirstFirst ... 2 3 4 5 6 7
    Results 121 to 134 of 134
    1. #121
      May 2016
      Ive decided to go a different route. Im starting with an all original 67 390GT. The plan is to lighten up the front end to within 50 pounds of a 5.0 which is pretty easy to do. Im still not 100% on which way i want to go with the build. Front end needs complete rebuild. I definitely want wider 255(ish) tires up front with 285(ish) rears. Electric R&P is a must. I would love to eliminate the shock towers. (Worst engineering design ever!)Name:  3E1D5939-AB29-4A42-928D-001427294D47.jpg
Size:  326.3 KBName:  3E1D5939-AB29-4A42-928D-001427294D47.jpg
    2. #122
      Nov 2018
      Quote Originally Posted by Mad tiki View Post
      I've always loved those old Cougars. They have a more refined look than the Mustang they're based on. Unfortunately, a full electric R&P is going to be a difficult add-on. The electric rack didn't come along until after CANBUS data, and (PLEASE someone correct me if I'm wrong!) so far as I know nobody's cracked the CANBUS/BCM connection well enough to use CANBUS-controlled accessories like electric racks.
      The solution I'm going with on my truck project is a manual rack and pinion with a Corolla electric column assist unit mounted to the firewall. This unit can either be controlled by a rheostat that lets you control the amount of assist by turning a knob on the dash, or you can rig up a speed sensor to automatically control assist by speed. I'm going to use one of these boards to control mine. Unfortunately, parts are on a shelf right now and I won't have this worked out until a year or two after I get my truck back from the frame shop. I was initially concerned with using a power steering unit for a 2700lb car on a 4000lb truck, but I think it will work because the Corolla is a front wheel drive and the truck is rear wheel drive, and the Corolla power steering has to cop with turning wheels under constant power. The extra force required to turn a powered wheel should be close to the same as the force required to turn a heavier unpowered wheel. Plus, I'm aiming to get the truck down closer to a Corolla's weight.
      That being said, if someone comes up with an HP-Tuners-like way to easily manipulate CANBUS stuff before I get mine built I'll probably change directions. An electric rack would be superior to a manual rack with an EPS box. It would be lighter, with all the weight lower down. Also, look under the Suspension section, there's a sticky there called "Toyota FRS Electric Power Steering in an A Body" discussing electric power steering.
      2021 Durango R/T
      2008 Colorado beater
      2003 Dakota project-o-mobile
    3. #123
      Nov 2015
      South Jersey
      I also went the different root with a 69 Cougar
      Name:  69 Cougar.jpg
      Name:  69 Cougar 2.jpg
      69 Cougar
      Schwartz Chassis
      5.0 Coyote
      T-56 Magnum 6 Speed
      Baer Brakes
    4. #124
      Nov 2007
      Dayton, Ohio
      Getting there, see link in signature.
      Roger
      69 Mustang coupe, under construction
      2011 Mustang - DD
      https://www.pro-touring.com/threads/...ang-SuperCoupe
      Freedom Of Speed!
    5. #125
      Dec 2009
      San Diego, CA
      Cougar for me. Hope I can get it off the back burner soon.
      Brother has a 66 mustang
      Robert Icasas
      Projects:
      67 Cougar
      Art Morrison Sport IFS
      3-link Rear Suspension
      Coyote w/ D&D Performance Viper t56
    6. #126
      Jan 2012
      I haven't posted in a while, but here is my contribution to the thread.
      521 cubic inch, Topoloader, Gear Vendor OD, 3.50 gears. 542hp 572tq at the ground on pump gas.
      Name:  Mustang engine.jpg
Size:  453.0 KBName:  Mustang numbered.jpg
    7. #127
      Dec 2020
      Revolution speed shop in auburn Wa. Loves throwing Coyotes into classic mustang
      There doing work for me on my chevelle. This a 69 they wide bodied. Pretty much all new custom panels, frameÖ. Well everything. Hood is super cool modeled after a Ford GT
      I believe itís getting a VooDoo just not sure if itís SC version
    8. #128
      Awesome!
      I do have one question...
      Can I have a ride? :D haha
    9. #129
      Dec 2017
      West Virginia
      That color combo really looks good with the wheels. Is that a custom mix blue?
    10. #130
      Jan 2012
      I am not sure if that question was directed to me, but my car is the original color, Gulfstream Aqua.
      Thanks.
    11. #131
      Dec 2017
      West Virginia
      It was for lxg44 on his cougar.
      But what was your car built towards? Beast of an engine
    12. #132
      Jan 2012
      The main goal was to run the Silver State Classic, and some standing mile events.
    13. #133
      Sep 2022
      Myrtle Beach, SC.
      I'm a new member and figured I would add some photos of a recently finished 66 fastback build.
      Long term project but pretty satisfied with the results.
      Hope I've attached the photos correctly.
Size:  270.3 KBName:  20210909_171345.jpg
Size:  188.5 KBName:  20210817_111142.jpg
Size:  210.0 KBName:  20200714_103152.jpg
Size:  198.0 KBName:  20200714_103102.jpg
Size:  195.9 KBName:  20200714_103035.jpg
Size:  196.6 KBName:  20200714_103014.jpg
Size:  214.2 KBName:  20200416_161441.jpg
Size:  169.3 KBName:  20200325_084726.jpg
Size:  205.3 KBName:  20210909_171420.jpg
    14. #134
      Nov 2018
      That is some outstanding work.
      2021 Durango R/T
