Originally Posted by
CarlC
Chad,
Some basic requrements:
1) The tank will need to have a 7" - 8-1/2" overall height in the area where the module will be mounted. 8" is ideal. A 1st-gen Camaro has a similar shape to what I believe you are describing.
2) Center of the hole for the module is approx. 4-5/8" from the front of the fuel tray. From there you will need a 3-1/2" radius to clear the module reservoir and venturi/corner pickup lines. The top and bottom of the tank also needs to be parallel so that the module will seat flush against the bottom of the tank.
3) What BSFC is your engine builder basing the fuel requirement on?
David,
I wish I could help but that's out of my control. I suggest talking to Hector at Rick's to find out the status of your tank. 620hp should be OK for yours, but you hit the nail on the head. What is it going to cost you now vs. what is it going to cost to do again?
3) The pump is from a 2010 CTS-V.
I can have aluminum rings made. If there is enough demand I can have some made but there is a setup charge that should be amortized over multiple parts. I there's five or more it would make the cost easier to swallow. So if you're interested in a modified large-flange aluminum ring, please chime in. If a larger aluminum flange was used then the ring could be placed anywhere and simple fabrication processes could be used. No tray needed.
