    Results 1 to 10 of 10
      Aug 2010
      Los Angeles
      Looking for 700r4
      Hey guys,
      I know some of you have swap to bigger and better things but I was hoping someone has a 700r4 lying around. Looking to hook it up to a 350 sbc.
      Feb 2011
      Northern California
      Where are you located?
      I have a 700R4 but would probably want to have it gone through for any performance applications
      It came out of a running GM TBI truck.
      I'm located in Northern California.
      Aug 2010
      Los Angeles
      Yeah, I'm kinda looking for a good to go set up but thanks.
      Feb 2011
      Northern California
      No Problem, Good Luck!
      Oct 2005
      Toronto
      I have a professionally built 700R4 that is one season old (2,000ish miles I'd guess,, biggest trip was Toronto to Wisconsin Face off event and then local driving only ) in a street 1970 383ci Z28 clone with a good/brand name converter (so I was told by the Trans shop I can find out) that works great for street driving..... I'm changing the car over to a new 5 speed Keisler RS600 because I'm not into an auto on the street for daily driving,,,, it's just not my bag...
      I initially did the car with an auto thinking my youngest son couldn't drive standard,,,,, boy did he surprise me when he hoped in one of my other cars and starting driving a standard like he'd been doing it for years right off the hop.... $1,500 cash firm for the transmission and converter (will not separate) delivered to the El Toro field in California while I'm out at the event.....
      Carbon Kustoms Limited
      A.K.A. Albert from Toronto
      Aug 2010
      Los Angeles
      That's a bit too much. I can do very close to that brand new but thanks for the offer.
      Feb 2011
      have a nice 700R4 out of a 86 Iroc. Was on a tuned port motor
      Apr 2010
      Jersey Shore
      where are you located? I have a worked over 700 for sale:
      700r4 Trans...Professional rebuild by Ziggy's Transmissions in NJ less than 15,000 ago. Rebuild included:
      New seals, gaskets, teflon and o-rings
      New filter
      Hardened Transgo pump rings
      New .471 boost valve & sleeve
      Raybestos Pro Series 2-4 band
      Rabestos Heavy Duty 3--4 Z-Pak
      Shift Kit
      Hydraulic lock-up
      Corvette servo
      Corvette governor
      Hardened sun shell
      020 Valve & sleeve
      New BW rear roller set
      Heavy Duty 2500 stall speed converter
      Complete bolt in set-up includes
      168 tooth flexplate (came off of a 1pc rear seal block)
      trans/converter dust cover
      tv cable
      TCI custom tv cable brackets for correct cable operation with a Holley carb
      dipstick and tube
      Hurst ratchet shifter complete with cable, hardware, handle, ball and console
      yoke for a 700r4
      finned aluminum tube style trans cooler
      trans cooler hard lines for a tri-five chevy
      **Yoke and custom tv cable carb bracket are not pictured.
      This set-up has less than 15,000 miles on it.
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
      Aug 2010
      Los Angeles
      I actually found one. Thanks.
      Dec 2007
      I have one, never ran, with all the best stuff, including the beast shell. I'll let it go for a good price if you are looking for other options.
      Thanks,
      Jon
