Results 1 to 20 of 34
Thread: 3" vs 2.5" Exhaust?
11-14-2010 #1
3" vs 2.5" Exhaust?
What is the determining criteria for choosing 3" or 2.5" exhaust pipes?
11-14-2010 #2Generally it has to do with horsepower levels. When you start approaching the 500 horse level you will see the biggest gains. Some folks will say it has to do with cubic inches, but that is not the case as much as power levels. Power and powerbands are really determined by the Header design and the exhaust will mostly only hinder the efforts of the headers, they can't really make it any better, unless the header design is really poor. So more exhaust flow is usually better. A 3" system on a 250 HP motor won't gain anything, but it probably won't hurt it either.
The new Mustang 5.0 comes from the factory with a 2.75" exhaust. I did a set up in all 3" for a well known Mustang car builder and they reported back a 23HP gain over stock. Now I'm sure some of that came from the fact that our mufflers flow much better than the stock Ford ones, but it certainly was a noticeable increase with the 3"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming 'WOW What a Ride!'
11-14-2010 #3Thanks for the advice Don. I have a 78 TA. I just ordered the Tri-Y headers from Ron Watt. I found Ron on this site as well. My motor is around 500HP so I'm going to run Pypes 3" exhaust with the crossover and Pypes race pro mufflers.
11-14-2010 #4Before you order the Pypes stuff, you might want to take a look at Ram Air Restorations products. I can tell you from first hand experience that the oval X-pipe, along with the actual X-Pipe design, will give you great performance with more ground clearance. 3" round is problematic on some cars and the oval design is wonderful.
11-14-2010 #5Thanks. I will check into that. Any preferance on mufflers?
11-14-2010 #6I'm real happy with the Spintech mufflers I got at the same place, but everyone has very different tastes there. Plus, sound varies so much depending on the engine build.
11-14-2010 #7My 347 stroker has 453hp on the dyno and I went with 2.5" exhaust.
"Project Scarelane" - 1967 Ford Fairlane 500XL Pro-Tour
11-14-2010 #8
11-14-2010 #9
