    Results 1 to 3 of 3
      Just outside Ann Arbor, MI
      Gear ratio for T400 & Gear Vendors
      I am wondering what thoughts you would have on a gear ratio for my car? The car has a T400 with a Gear Vendors overdrive, goal is to have good accel from bottom end up so I can enjoy toying with other cars without having too much gear for crusing on the highway
      I am hoping to order the parts in the next week or two and so far the discussion I have had revolve around using a gear set of 3.73...
      Thanks!
      Dion
      67RSSS502
      thoughts anyone?
      Ontario, Canada
      The 3.73s would work well, and with the overdrive you may even be able to run 3.91s or 4.10s.
      If you do a lot of cruising on the highway, you may be better off choosing a ratio to give you the best cruise rpm at highway speeds.
      Don't forget to take rear tire diameter and overdrive ratio into consideration when you choose a ratio for the rear end. When selecting a cruise rpm, don't forget to take your camshaft into consideration. If your revs are to low, it could cause drivability problems.
      Here's a calculator I use a lot.
      http://forcedpsi.com/Calculators.html
      Ken
      My other car is a Vega.
