    Page 1 of 7 1 2 3 4 5 6 ... LastLast
    Results 1 to 20 of 128
      May 2010
      Phoenix AZ
      1966 F100 450/510 Raptor Crate Engine 10R80 Combo
      My build is a 1966 F100 Short Bed Custom Cab
      Kind of a Sleeper Build but getting a infusion of MORE power, Better Brakes, Lower Ride Height, Updated Suspension, Tires & Wheels.
      The wheels for now are going to be custom made steels until its back on the road and I can find a step up again for better brakes for a 5 on 5 wheel "OR" I can find brakes and go to 5 on 4 1/2. Once its on the road that will be the next step.
      Engine is a 427 Side Oiler which will be displacing 482 Cubes
      4.25 x 4.25.
      Engine base is a new Genesis Block, 4.25 Stroker kit, CNC'd Edelbrock Heads, Custom Quick fuel carbs (750+cfm each). Intake manifold is a Factory Ford Tunnel Wedge Dual Quad. Oil Pan is a Custom 7qt Road Race Unit.
      Trans is a 1969 428 Cobra Jet C-6 with a custom Converter
      Rear is a 9" with a Yukon gear Posi Unit (tight version) Running 3:50 Gears
      This is prior to teardown. Other pic links lost. Updating links. 4/8/18
      A very long project. 1st pic my middle daughter who is getting married next weekend. Older daughter married with family. Where does the time go?
      From outside and a quick view of interior it will look stock. With exception of being a fair amount lower along with tire wheel package.
      May 2010
      Phoenix AZ
      Teardown time. Front clip is off and so is the cab along with the original
      300 6 cyl
      Building carts to hold the box and cab. The cab cart fits on top of the box cart for sandblasting etc
      May 2010
      Phoenix AZ
      Engine Mock~up
      Sand Blasted Frame
      May 2010
      Phoenix AZ
      This was pre-fitting the engine and trans. Close but it Fits!
      Pics above. Try;ing to edit broken links
      May 2010
      Phoenix AZ
      Frame and other chassis components back from the Powder Coater
      May 2010
      Phoenix AZ
      I started to build this car but when I moved had to give it up.
      If anyone knows where its at I would like to buy it back. Last I knew it was in Tennesee
      Mar 2010
      AZ
      Looks nice, those trucks had pretty impressive suspensions from the factory, at least for a truck. Are you planning any mods?
      May 2010
      Phoenix AZ
      Quote Originally Posted by ArtosDracon View Post
      Mods are: The 482" motor, adding 77 F150 power disc brakes, dropped I beams in the front, Power Steering.
      Also plan on adding front and rear bars but have not figured out exactly what yet. I expect it to handle pretty well as you say for a
      "truck". I will need help on chosing the proper sway bars. Not much made for these trucks in performance suspension or brakes.
      I expect the weight to be around 3650lbs. My modern day shelby is 3900...
      The engine is set back as far as I can get it without chopping the firewall. #1 plug is back of axle centerline which is good compared to most cars but still a truck. I would like to "track" it once its done then get into tuning the chassis.
      Close-up of carts
      stripping of paint
      Arizona Truck so sheet metal is very nice for a starting point.
      Box floor had many small little dents. Started to shrink each one but decided to install new floor after finding out the 2008 Super Duty floor were near exact dimensions. 225 spot welds later...
      May 2010
      Phoenix AZ
      Engine, Trans and Rear Axle parts start to show up
      Very unfortunate someone put a bottle jack under the trans and popped a hole in it. Nothing a little Tig'n could not take care of
      My first Auto trans rebuild so lets hope it works.
      May 2010
      Phoenix AZ
      Engine Time!
      Assy process
      May 2010
      Phoenix AZ
      All bare metal and time for primer
      May 2010
      Phoenix AZ
      Finally in primer
      May 2010
      Phoenix AZ
      After sanding each nook and cranny, re-prime, then sand again its finally ready for sealer and paint
      May 2010
      Phoenix AZ
      About the only real repair on cab was the cutout for radio that was kind of hacked. Easy fix.
      Chassis going back together
      Mar 2010
      Rochester NY
      Nice work -- My first vehicle was a Ford F-100. I loved that truck and hope to have another some day. This would do
      Grace - 67 Camaro daily driver with upgrades along the way.
      https://www.pro-touring.com/showthre...-Camaro-Driver
      May 2010
      Phoenix AZ
      Quote Originally Posted by Dons67 View Post
      Thanks! My dad brought a new 66 F100 home October of 1965 and I fell in love with them way back then. Its what I learned how to drive in and what I used. He then gave me the truck around 1984.
      Engine going together
      wow killer project! looks great so far!!!
      May 2010
      Phoenix AZ
      Quote Originally Posted by CruizinKev View Post
      Thanks!
      Cab ready to go back onto completed chassis
      Fontana, CA
      I love it. Makes me want to redo my '62 F100. Camaro is first in linr though.
      Nick R.
      May 2010
      Phoenix AZ
      This is where its at right now. Still a ton of work left to do but finally looking like something has been done.
      Trying to do the complete truck for under 25k. Looks like it may be possible. A HUGE chunk of that was spent on the engine. Close to 50%
