    Page 21 of 31 FirstFirst ... 11 16 17 18 19 20 21 22 23 24 25 26 ... LastLast
    Results 401 to 420 of 614
    1. #401
      Aug 2002
      Sweden
      Country Flag: Sweden
      Upper part of the rad support:
      Welded
      97% finished now. Some minor parts left, but I'll save that for later. Gonna start on the reinforcements that you can see is mocked up with blue tape in the pic below.
    2. #402
      Jul 2011
      Prescott, AZ
      That support looks beautiful. Do you plan to shroud the fan on that bad boy?
    3. #403
      Sep 2011
      Southern Ontario
      Why is the rad on an angle? To minimise the height for packaging or for cooling puropose's?
    4. #404
      FRANCE
      Country Flag: France
      Awesome ! Love your work... So impressive & inspiring.
      Wish I had the knowledges for half of it...
      I need to install my SFC's on the Bird now.
      Gil
    5. #405
      Brisbane Australia
      Country Flag: Australia
      Beautiful
    6. #406
      Aug 2002
      Sweden
      Centerforce; it's prepared for a duct from the front to the rad. The fan will probably only be needed in 20MPH or less.
      Something like this:
      If I cut a hole in the hood, I'll add an duct after the rad up to the hood too. Haven't decided upon that yet though. I like the Ram Air/Formula-hood and then there's no space for a outlet, but I also have a standard hood saved so we'll see what happens.
      Peter; it's angled because of two reasons; As I wrote above, I needed room to build a duct after the rad and up through the hood. But I also wanted to make room above the rad support to be able to feed the engine with air directly from the grille. Right now, I'm not sure I'll do any of it though, lol. Just realized yesterday night that I probably could do a nice air channel from the windshield instead, and regarding the air channel I'm leaning towards a Formula hood.
      Gil: Thanks!
      I did my SFCs like this: http://www.propontiac.com/subframeconnectors/
    7. #407
      The Netherlands
      Country Flag: Netherlands
      amazing work as always Anders!
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
    8. #408
      Jul 2011
      Prescott, AZ
      Quote Originally Posted by Ripper View Post
      Perfect! We figured you probably had a plan for one, based off of everything in this build so far!
    9. #409
      Aug 2002
      Sweden
      Since my new ECU (DTA S80 PRO) has a couple of good features compared to the old one (Electromotive TECII), I decided to add a cam-sensor.
      How it looked before:
      Index-thing...
      Mounted on the cam-wheel
      Reference on the front panel
      Kind of nervous here. My mill has proved to have a insatiable hunger for aluminium. You never know if it decides to eat the entire part...
      But it turned out good though
      Welded and final milling done
      Painted... in cast iron grey. "just add lightness", lol.
      Assembled and done
    10. #410
      Chicago
      Very cool
      marty-mj
    11. #411
      Sep 2009
      Assembled and done
      Is that an A/C compressor?
    12. #412
      Of course! Because Racecar!!!
      Instagram @projectgattago
      Dr. EFI
    13. #413
      Apr 2011
      Nice work! By the way, what brand are those hold down clamps?
    14. #414
      Feb 2013
      Awesome!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    15. #415
      Aug 2002
      Sweden
      Exactly. Some comfort will be added (i.e. AC)
      - - - Updated - - -
      Quote Originally Posted by hotrod56 View Post
      Thanks!
      Those are Luna, Swedish made and basically called "speed clamps". I like them for these kind of jobs where you don't put alot of load on the stock/part.
    16. #416
      Apr 2011
      Thanks for the clamp info. Where can we find them?
    17. #417
      Brisbane Australia
      What benefits do you get from adding the cam trigger? Is it so you can run sequential injection?
    18. #418
      Fresno, Ca
      Anders,
      You NEVER fail to blow me away with your fab work-- the cam sensor-- GENIUS!!!!!
    19. #419
      Aug 2002
      Sweden
      Yes, sequential injection is the plan. I'm not into engines, but I have a friend who is. His argument (except for easier startup) is; emission/consumption, idle and low load(?) on the engine. On full throttle it doesn't really matter, but the engine runs smoother on cruising thanks to the possibility of finer tuned injector settings.
      Again, I'm not an engine guy but I trust him.
      Don't you have these in US?
    20. #420
      Aug 2002
      Sweden
      Quote Originally Posted by PonchoJohn View Post
      Anders,
      Thanks!
      You better sit down then, because from here it will only get better!
