    Page 18 of 31 FirstFirst ... 8 13 14 15 16 17 18 19 20 21 22 23 28 ... LastLast
    Results 341 to 360 of 614
    1. #341
      Chicago
      I seriously love this build not only for the quality of the pictures but for the attention to detail.
      marty-mj
    2. #342
      McKinney, TX
      This thing is amazing, I am in awe.
      89 Mustang "Box Wine"
    3. #343
      Aug 2002
      Sweden
      Country Flag: Sweden
      Thanks guys!
      I really appreciate the feedback!
      It keeps me motivated.
      Regarding picture quality - well.. Yes, I think that's important. The only drawback is that it takes some time to rig before taking a picture, so the spontaneous pictures has almost disappeared from my project library.
    4. #344
      Mar 2014
      Yuma, AZ
      Glad to see progress is being made, you sir are excellent at fabricating! When this is done I have no doubt it would be able to run with any of the big name cars! Keep up the good work!
      Nelson
    5. #345
      Merritt Island,FL
      Great build, love it ! Very nice work and skill !
      Check out my web site.
    6. #346
      Chicago
      Quote Originally Posted by Ripper View Post
      Thanks guys!
      Save the Spontaneity for your wife or girlfriend they will be more appreciative then us guys. We like the picture quality and now that I am back on my 70 I am going to strive to take better quality pictures.
      marty-mj
    7. #347
      Aug 2002
      Sweden
      Lol, I'll save the spontaneity for her instead.
      Some updates: I was going to use a balance bar for the brake setup but I didn't wanna integrate it into the firewall since there's a chance I wanna upgrade it with a brake booster in the future.
      At first, I was going to make one frome scratch, but I scrapped that idea when I came over an empty housing cheap.
      My initial concept (the balance bar itself is missing...)
      The housing:
      With wilwood cylinders:
      Nothing is bolt on in my world...
      Obviously the housing was empty, so I had to purchase a wilwood balance bar. There was no rocker arm included. A new costed 125$, so I made one by myself. Of course the balance bar was inch-sized outside and I only had metric reamers, so I turned a new steel tube for the balance bar too.
      I want a sealed firewall, so I had to locate a gaiter in reasonable dimension and to fit that to the housing, I 3D-printed a flange to hold it.
      Alot of engineering which I forgot to take pictures at, of course...
      Alot of engineering which you don't even see... I must be crazy, but you should have realized that by now.
      Another picture with the lines connected.
      I wanted swiveling AN-units, but couldn't find any so I used fixed ones and tightened them as much as possible and used some extra PTFE tape. They sit tight, but since I had to have them in a certain angle, it was probably possible to tighten them another 90º before until they really really _really_ tight.
      I'm not worried, but I'll test it when there's fluid in the system
    8. #348
      Chicago
      Since there isn't a like button I will just post one here.
      Name:  like button_full.png
      marty-mj
    9. #349
      Aug 2002
      Sweden
      Ok, suspension... I've probably mentioned that I raised the fenderlips appr 40mm (1,5" or so) to make the car really low but still don't have the wheels inside the fenders.
      Ground clearance will be 80mm and I've almost finished my exhaust (which was a real pain to build and prevent from hanging down).
      I really wanted good dampers/springs so airsuspension was never considered. But since it's not a 100% race car, I still needed to solve the battle of speed bumps and the urban djungle. To do this, I teamed up with a friend that shared the same problem for his Bentley Expedia replica (yes, the Le Mans winner...) since he had CNC-machines. I designed, he manufactured two sets.
      This is as close to bolt on parts I'm coming, lol.
      It's basically hydralic pistons shaped as tubes, made in aluminum and then hard anodized. Some minor tricks in them to keep them compact and light weight, but still capable of lifting the car.
      I'll put them on all four corners to be able to lift the entire car 2", but front would be enough. They will hopefully lift all corners at the same time if I manage 50/50 weight ratio, but we'll see. Plan B is to have a separate circuit for the rear.
    10. #350
      Dec 2010
      Apex, NC
      Well, there's still an insaneously amount of work until it can be started. Electrical system, fuel system, the rest of the exhaust, cooling, rad support etc. All custom made. I guess I have another year until it's started and running.
      I'm trying not to think about that too much, because it's crazy when I realize I've been working on it since 2009...
      Catching up on your posts. Outstanding work! and yes, never, ever , under any circumstances, do you think about how much is left. Just chip away
    11. #351
      Aug 2002
      Sweden
      Thanks!
      Yes, it's really hard to find motivation when you realize it's probably another couple of years until it's finished. But I try not to think about it.
      Ok, I needed a pump for the lift-system. I got this pump from a friend, which is a 12v system from a pallet truck. Complete system with all electrics etc. Almost plug and play
      It needed some clean up to fit the Pontiac-standard, so I 3D-printed a new fixing point for the fuse block so it could be taped to the motor. I copied the click mount from the plastic piece I threw away so I could mount it in the same way as stock.
      (3D-printed to the left)
      Also included a mount for the connector to the switch so it didn't hang loose anymore.
      Now it looks better (taped the cables also)
      Made a mount to attach it (otherwise I would have to position the pump inside the coupé and enter the bolts under the car - too short arms to do that)
      So, here it is. Sitting behind the driver seat. I'm gonna fit a extinguishing system there and then cover everything with some panels... in the future...
    12. #352
      Aug 2002
      Sweden
      I replaced this:
      With this:
      I used the beam/reinforcement allready integraded into the body. Cut it up and welded mounts (attached to a fixture, of course, so I know the future C-C measurement) to it and made a quick mockup to find out what measurements the new member should have:
      When it was measured, I made some parts in CAD and ordered these. Two tubes later it looked like this:
      Well, there was actually a smaller modification to fit the exhaust on the passenger side since the transmission is moved slightly towards the passenger side. To do that, I chamfered the member slightly (which explains the welds on the tube - small accident with the angle grinder...)
      And here's my new exhaust. Was going to be a temporary exhaust, but I'll probably develop this more in the future until I'm satisfied with the sound.
    13. #353
      May 2009
      Connecticut
      Fantastic build! Is the crossmember bolted to a captive nuts inside the tunnel?
      Aldin
      1969 Camaro (Weapon of Choice) in the works
    14. #354
      Aug 2002
      Sweden
      I used weld nuts inside the profile. When I googled captive nuts they looked weaker than what I used but principle is the same.
      This is what I used:
    15. #355
      Apr 2011
      Where do you get them?
    16. #356
      Aug 2002
      Sweden
      You mean where in Sweden I got them? ;)
      (i.e. Swedol has them)
      A quick ebay search found a couple of different dimensions:
      http://www.ebay.com/sch/i.html?_from...d+nut&_sacat=0
    17. #357
      Oct 2015
      WARNING! Never google "Captive Nuts". It gets really weird.
    18. #358
      Dec 2011
      Planit Oahu, Hawaii if you don't belive me check shipping prices
      Have you considered manufacturing those?
      I would Like a set.
    19. #359
      Nov 2007
      Dayton, Ohio
      quoted wrong post
      Roger
      69 Mustang coupe, under construction
      2011 Mustang - DD
      https://www.pro-touring.com/threads/...ang-SuperCoupe
      Freedom Of Speed!
    20. #360
      Nov 2007
      Dayton, Ohio
      Quote Originally Posted by hotrod56 View Post
      You can get them at McMaster-Carr. I've gotten them there before.
      http://www.mcmaster.com/#weld-nuts/=10b5upb
      Roger
      2011 Mustang - DD
      Freedom Of Speed!
