    Page 13 of 31 FirstFirst ... 3 8 9 10 11 12 13 14 15 16 17 18 23 ... LastLast
    Results 241 to 260 of 614
    1. #241
      Brisbane Australia
      Country Flag: Australia
      Just a compelling build. Thanks for sharing
    2. #242
      Chicago
      Quote Originally Posted by linkstar69 View Post
      Ditto what he said. I am loving seeing this car come together
      marty-mj
    3. #243
      May 2001
      Mesa, Az.
      This is the first I've seen this thread. Isn't it funny how you can miss stuff for so long on here? Great work! Thanks for sharing.
      Phillip
    4. #244
      Aug 2002
      Sweden
      Country Flag: Sweden
    5. #245
      Mar 2013
      wow... Awesome work.
    6. #246
      Mar 2014
      Yuma, AZ
      You do some amazing work! Hopefully by the time I'm out of school I can design things half way as good as you can! Keep up the good work!
      And I'm glad you kept the Pontiac motor, there's already too many LS powered pro touring cars haha
      Nelson
    7. #247
      Aug 2002
      Sweden
      Subframe in place. Permanent!
      Slightly nervous since I didn't test fit it between welding and painting. Approximately 13ft of welding total so I was nervous that it would have warped. However, it slipped right in. Like a glove!
      I made my own guide pins. Instead of having to align the subframe against the body, the subframe is now self aligning.
      Some fasteners for the subframe
      And the subframe:
      And in the same moment the subframe sat there, I couldn't wait... i just had to start assemble everything else...
      First out was my rack and pinion from a Ford Sierra, shortened 8" (200mm), gun drilled shaft to save weight and new mounting points to the subframe.
    8. #248
      Aug 2002
      Sweden
    9. #249
      FRANCE
      Country Flag: France
      Amazing ! Love it...
      Always drooling when you update...
      When are you planning a little Getaway in Stockholm vid ?
      Bada$$ x 10000...
      Gil
    10. #250
      Nice work.
      What the plan for transmission and clutch?
      Instagram @projectgattago
      Dr. EFI
    11. #251
      Chicago
      Amazing !!!!
      marty-mj
    12. #252
      Aug 2002
      Sweden
      Thanks guys!
      Getaway in Stockholm, lol.
      Andrew: I'm running the same drive train as I did before. A 400cui, a LT1 T56 and a centerforce 11" clutch. I know those things works (since I used them before) and I'll probably be busy tuning the chassis during the next years so sorting out a drive train would be nice to avoid.
      There are some new parts though - a 3.5" aluminum drive shaft and the Ford 8.8 carrier (from the lincoln Mk VIII rear suspension).
      Some more pics!
    13. #253
      Aug 2002
      Sweden
      Some updates...
      Having a hard time to decide what type of gas cap I'm going to use...
      I'm aiming for a classic 60s look but the modern cap is kind of cool too. It'll probably destroy the classic look, so I'll probably end up with the Le Mans style cap anyway.
      Uprights...
      The upper A-arm being fabled. I made a real stable weld fixture since the arms are the first thing to break/bend if you run out of asphalt.
      It's hunting season on heavy stuff... Lightweight bolts... Every ounce counts :D
      Uprights, center bolt axle and A-arms finally finished and together. It's starting to look like a car!
      And I got on the cover feature of Speedhunters Creators Theme too! That was a really great feeling! They must have gotten hundreds of e-mails with crazy projects and they chose mine! I still can't believe it.
      The speedhunters article is here: http://www.speedhunters.com/2014/11/...reators-theme/
    14. #254
      FRANCE
      Quote Originally Posted by Ripper View Post
      Because you are the craziest ! You are the man !
      Awesome build... Le Mans style cap looks nice...
      Congratulations !
      Gil
    15. #255
      Vancouver, BC
      Just PM'd you with a couple questions!
      And ditto on the Le Mans style gas cap. Again.. fantastic stuff here.
      1972 Nova, forged LQ4 with twin 6466's, T56 Magnum, OEM subframe w/ Speedtech front, Chassisworks gLink rear, Ridetech coils & Wilwoods, with a rear floater in the works --> http://www.ls1tech.com/forums/conver...1972-nova.html
    16. #256
      Jun 2006
      Minneapolis MN
      Absolutely fantastic build. Keep it coming.
      71 LS1 SOLD 6-24-6
      Future Plans: LS2/T56 in 70-73 camaro
    17. #257
      Aug 2002
      Sweden
      Thanks guys!
      Here are some more updates.
      Made some spacers for my rod ends. 28pcs to be exact...
      Hand made in the lathe so it took some time to get them all.
      Just an overview on the rear suspension. I'm gonna take the de dion down to do some smaller mods on it. Probably a good idea that I left it in primer...
      Front suspension one step closer being done:
      285's up front on a 10" rim. 10,5" rear with same width.
      And reality vs. CAD
    18. #258
      Aug 2014
      If those are your welds on speed hunters show some more pics they look amazing. Great build
    19. #259
      Waterloo, Ia
      Awesome talent and great vision. One of the neatest all around builds iv'e seen on this site or anywhere for that matter. I'm really looking forward to the finished product!
      -Nick
      -1967 GTO I drive and race
      -Build threads:
    20. #260
      Did you build some camber into the spindles?
      How will you change the alignment?
      When you post pictures, can you size them bigger, maybe 1000 pixels wide? I think most people have high res monitors these days and the detail would be appreciated. :-)
      Dr. EFI
