    Results 1 to 18 of 18
      Jan 2010
      wish I knew someone to fix a steering column
      Need my steering column fixed. ignition rod does not move when I turn the key
      Going to be atleast $200 not including the $150 tow
      Rustburg, Virginia
      See if this helps any, it's for a camaro....but a T/A should be similar
      ...it is for a non-tilt column.
      and this one is for the tilt column:
      England
      I have this problem with mine there's a shaft running down the col that connects to the wiring block at the bottom take the plastic cover off and give it shove up and down while trying to turn the key this normally fixes it.It just needs realining with the block.The rod is number 51 on the 76-81 standard col going into num 24,or rod num 22 on the tilt
      Rockford Illinois
      For $350 you can just about buy a new one and forget about fixing it.
      Quote Originally Posted by Jim Nilsen View Post
      for $0 and some time, you can pull it apart and figure out what's actually wrong with it- it's really not all that complicated.. a steering wheel puller and lockplate tool makes it much easier, so add $10 to my first estimate to get those tools.
      Rockford Illinois
      Quote Originally Posted by novaderrik View Post
      I actually bought a whole other column at a swap meet for $30 and was able to use the best parts from both to make one good one. I was also able to learn how to pull it all apart and not have to worry about ruining something. They aren't that complicated but some of the parts can be a pain to keep from falling all over until you figure it out. Whoops there goes those bearings,lol.
      If he needs parts I still have some in a box just in case.
      Central CA USA
      Part number 40 on the tilt column is made of pot metal and often breaks. Most dealers have lots of practice replacing them. The only hard part is pulling the pivot pins but I made a puller of my own.
      Feb 2014
      I have a column shift with non tilt or fixed column. When I drive it the column shifter is really loose and falls downward causing the car to down shift. What parts could be warn out and are they easy to fix. The expanded view of a column shows many parts.
      Feb 2014
      Quote Originally Posted by David Pozzi View Post
      Do you have any pics of the tool you made?
      Jul 2008
      milton, florida
      you can buy the pivot pin tool at o'reilly for about 5 bucks
      Feb 2014
      Thanks. Does it sound like column parts to you? A friend said it could be the tranny linkage?
      Jul 2008
      milton, florida
      if the trans is downshifting without you moving the shifter, it could be a number of things, first thing that comes to mind is the shifter arm bracket could be worn down or broken off, number 52 on the tilt and number 26 on non tilt, other than that I need to get into the column and see whats wrong, Jim
      Jul 2013
      Gilbert, AZ
      Quote Originally Posted by TravMitch View Post
      It sounds like the detent plate at the base of the column is the issue. Is the shift lever still spring loaded, i.e. can you pull it rearward, and it pulls itself back to the front of the car? If so, it should pull itself forward into the detent plate, which is what makes you pull the arm back to remove from park, the back to go from D to 2, and back again for 2-1, it should never be able to just "fall" down the gears. (I'd refer to the drawings above, but those are for floor shift columns which won't have the detents)
      Feb 2014
      I looked at my shift indicator and it only has (Park R N D L) Not Park R N D 2 1
      Would this mean my car was a 2 speed power glide and the detents for a T350 would be different? My friend gave my the T350 out of his 73 Nova because he is going with a 4 speed manual. Now he has given me his column from the 73 Nova also. I have tore both apart and they have different detents on the column part with the key and the long neck park behind it. I plan on putting his detents in my car and hope it fixes my problem.Name:  014.jpg
Size:  140.3 KBName:  015.jpg
Size:  175.1 KBName:  019 (2).jpg
      Central CA USA
      Should work.
      Long ago I swapped out a Powerglide for a TH350. Our 68 Camaro had a floor shift with cable. It worked fine with the PG detents, I just could not select 1st gear manually which didn't bother me. All the rest worked fine with a little adjusting of the stud on the trans shifter arm.
      Jul 2008
      milton, florida
      if you need and parts for a non tilt I have plenty, the non tilts are a little more of a pain to build than tilts, looks like the one on the left is for a glide and th350 on the right
      Dec 2011
      Oregon coast
      I've rebuilt a column before, not easy but not hard. Just make sure you have a big clean table and lay everything out sequentially as it comes off the column. All the parts are pretty easily available..
      Harriman, Tennessee
      Quote Originally Posted by boss_hoss View Post
      The last post before yours is from 2014.
      You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
