Results 21 to 30 of 30
02-09-2010 #21
I have a real life example of this, it really shows all the variables that go into the best exhaust. It's not really a simple 'flow' issue as I would have thought. Need to consider transition point in the headers, tuning length of headers/collectors and how it all reacts to the exhaust. (I've researched this so much my head spins)
Recently with FUeL (525 RWHP) we changed the headers to fit with a new DSE front clip upgrade and left the exhaust (2.5) exactly the same. With no other changes we lost about 15hp and torque peak moved from down to about 4000 from 5200. The new headers technically better 'should' have increased performance, so I would have thought? The old exhaust was 2.5. Un-bolting the old exhaust on the dyno we gained back the loss? So the conclusion was the 2.5 exhaust with the new header was chocking it out. Every thing has been now changed to a 3.00 exhaust and it 'better' have solved the issue! Still waiting for the new dyno time and results-(fingers crossed)
pretty new exhaust pic...
Dave
68 Corvair coupe
65 Impala SS
64 Corvair Rampside
62 Corvair Greenbrier
Asst. daily drivers
http://www.sourceboards.com/
02-09-2010 #22I enjoy the technical aspects of this so let me take a stab at what I believe is going on.
Venturi Effect
http://www.youtube.com/watch?v=Z4AbzQyLPcE
When air exhuasts from the combustion chamber at high speed it will create a venturi effect only when a pressure differential is created by first restricting the flow and increasing the pressure at the heads then decreasing the pressure and increasing the flow to create a vacum and help to empty the exhasut chamber more effiecently.
Two large an exhaust and you loose this effect.
Two small an exhaust and you restrict the gas flow and do not allow the engine to vent.
How does that sound?David
1968 Camaro in many pieces
02-09-2010 #23
