    Page 14 of 15 FirstFirst ... 4 9 10 11 12 13 14 15 LastLast
    Results 261 to 280 of 281
    1. #261
      Oct 2009
      Reno, NV.
      Also got rid of the v-belts and went with an 8 rib setup from CVF, and swapped the Powermaster for a Mechman alternator
      Joe M
      '67 Firebird
      My build thread: https://www.pro-touring.com/showthre...irth&highlight=
    2. #262
      Nov 2018
      Very nice looking car. I always preferred the Firebirds to the Camaros in that era.
      Quote Originally Posted by 67rstbkt View Post
      - - - Updated - - -
      Attachment 190085
      If I might suggest, next time you have the grill off, a little flat black on those cooler line fittings behind the bird emblem and they disappear, no longer to distract from the nose.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
    3. #263
      Oct 2009
      Reno, NV.
      Quote Originally Posted by Vimes View Post
      yea - true - it’ll probably be awhile before that happens. I might try a little bit of loom on them
      Thanks!
      Joe M
      '67 Firebird
    4. #264
      Jan 2020
      UT
      Good to see an update on this build! Looks like you have put a lot of work into that interior and it is looking great.
      Also, that is an intense serpentine belt!
    5. #265
      Sep 2009
      Great work on the interior and the stance is perfect.
    6. #266
      Oct 2009
      Reno, NV.
      Quote Originally Posted by Fierbird67 View Post
      Thanks! It's from CVF Racing - I figured if I was going to do it, might as well go with the 8 rib setup
      - - - Updated - - -
      Thanks!
      Joe M
      '67 Firebird
    7. #267
      Jul 2019
      Ohio
      Yea, still here and slowly chipping away at this. I painted it and started working on the cut/buff
      beautiful color - what is it?
    8. #268
      The car looks great, nice work.
    9. #269
      Oct 2009
      Reno, NV.
      More updates - My trans was grinding under hard shifts from 1st to 2nd, so I pulled that out and sent it off to Tick for their level 2 rebuild and new bearings. They also had to replace 2nd and 6th gear, and 5th gear synchro assembly. I'm thinking a Supercharger is going to be the next upgrade. Pics soon....
      Joe M
      '67 Firebird
    10. #270
      Oct 2009
      Reno, NV.
      One Torqstorm Supercharger, Installed. First run on the dyno yielded 512hp/580tq at 5psi. That's a solid 100 on both over NA. I'm running Water/Meth as well. I think it's got a little more in it.
      Joe M
      '67 Firebird
    11. #271
      Oct 2009
      Reno, NV.
      A few more mods - I made some cover panels, swapped out to a bigger air filter, made a hole in my inner fender, and created a heat shield over the header on the passenger side - trying to keep the IATs lower
      Joe M
      '67 Firebird
    12. #272
      Jul 2019
      Ohio
      That looks very nice! That filter is huge.
    13. #273
      Oct 2009
      Reno, NV.
      Quote Originally Posted by srode View Post
      Thanks, lol!
      Joe M
      '67 Firebird
    14. #274
      Dec 2011
      looks great
    15. #275
      Oct 2009
      Reno, NV.
      Quote Originally Posted by oldschoolmuscle View Post
      looks great
      thanks! The lower section is Subaru Rallye Blue - the top is Electron Blue Satin single stage from TCP Global
      Joe M
      '67 Firebird
    16. #276
      Dec 2020
      How is the torque storm running? Thinking of one for my chevelle.
    17. #277
      Oct 2009
      Reno, NV.
      Quote Originally Posted by FORDvsCHEVY View Post
      No complaints so far, it does what I need it to do. I’ve got the 3.1 pulley on it on my 461 and I’m
      at about 4K altitude. Seeing around 5psi
      Joe M
      '67 Firebird
    18. #278
      Sep 2017
      Ditto on all the glad to see another 67 bird. Shes over the bad hump whenetal is done. cuddos to you for doing the metal work it looks great. And like others cool on keeping it real pontiac poncho madness
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    19. #279
      Oct 2009
      Reno, NV.
      Quote Originally Posted by TANKMASTERJ View Post
      Jason
      Thanks!
      Joe M
      '67 Firebird
    20. #280
      Sep 2009
      Very nice upgrade! I've heard a lot of good things about the Torqstorm units. Did they provide the serpentine belt setup or is that something you had before?
