Results 241 to 260 of 402
09-28-2017 #241
Thanks Dan and you're right on the fun never ending. The only positive is I'm getting all the floor work done at the same time, new metal to replace the rusted part, plus all the work for the roll bar and bracing/brackets for the new seat belt/shoulder harness setup. Then the floors can be POR 15'd, touched up with the original paint code 43 lime green, re-dynomatted, and carpeted. All kinds of "might as wells" and new discoveries to be worked on like just about every project on our cars. The good thing is nothing surprises me any more!!
Joe Lincoln
Lime Green 71 Olds 442 Convertible
Upgrades thread: https://www.pro-touring.com/showthre...ible&highlight=
09-30-2017 #242Registered User- Join Date
- Apr 2017
- TX
- 138
I wish we lived closer together, we would definitely have to line em up.
Dan
09-30-2017 #243Maybe we can find an event or track to meet at some day. If I ever get the car done I'm hoping to do lots of events - 1/4 mile, 1/8 mile, cruising/touring events, and some of these autocross events like the one UMI just had in PA last month. Was hoping the car would be done and ready for that but it just didn't happen. I'm really looking forward to testing out all the suspension upgrades (new AFX spindles, new steering box, & new chassis brace) Of course I still have all the body work to do so will have to decide if I try to drive it through the winter "as-is" here in Virginia Beach or make some progress on all the body work projects...we'll see.
Joe Lincoln
09-30-2017 #244Lots of progress on the roll bar today:
removable crossbar and downbars:
close up of shoulder harness belt and pic of crossbar disconnected:
Close up of belt at the bottom - Frank did an amazing job of adding a plate and a custom bracket for the lower belt to bolt to:
Joe Lincoln
10-29-2017 #245Had to change the door bar plans. Since the door bars can NOT be "swing out" because they mount too far behind the door opening (so the mount will also work with the shoulder belt when the door bars are not installed), had to make the bar straight instead of having the big bend in the middle. The positive is it looks much better than having the bend in my opinion. The negative is the arm rests have to be removed every time the door bars are installed. The reason the big bend didn't work (which would have eliminated the need to remove the arm rest every time) is I couldn't get in and out of the car with the door bar installed with that big bend and it not being "swing out".
Joe Lincoln
11-14-2017 #246A few new updates - rusted passenger side floor board has been replaced and passenger side door bar is in:
Driver's side
- - - Updated - - -
Dynamat added:
Joe Lincoln
11-14-2017 #247Most will be like WTF is this but adding it anyway - the battery shut off switch allows anyone to shut off my car alarm so a pin has been added to prevent shut off when it's in place:
this is the shut off switch I'm referring to:
Joe Lincoln
11-14-2017 #248racing harness tabs added:
hood light and windshield squirters added:
the "442" shifter handle is not going to work "as-is" will need to be shortened and rebent:
Joe Lincoln
11-16-2017 #249Registered User- Join Date
- Apr 2017
- TX
- 138
I figured I would give you a reply, It seems like I am talking to myself on here sometimes lol.
Dan
11-20-2017 #250Joe Lincoln
11-20-2017 #251Registered User- Join Date
- Sep 2013
- sw Kansas
- 1,645
