    Page 1 of 21 1 2 3 4 5 6 11 ... LastLast
    Results 1 to 20 of 402
      Apr 2008
      Virginia Beach VA
      Lime Green 71OLDS 442 convertible
      71 442 Convertible
      Thanks to Brian Trick, Steve Dembowski, Smitty, and Frank & Terry Trimble for their work on this car over the years!!
      468 (4.185 Bore, 4.25 stroke)
      528 hp @ 5500/563 ft lbs @ 4300 - at the crank
      Edelbrock heads - (older chamber design) milled to 69 CCs, ported 330/220 @ .600
      Torker - port matched
      custom dish diamond pistons (-20 cc dish)
      7" Scat steel rods from Rocket Racing
      Measured 11.1:1 CR (4.185/4.25/69ccEbrocks/20ccdish/zerodeck (pistons slightly out of the hole)/.038compfelpro)
      Studs, Main straps, oil restrictors
      Canton Racing 15-502 baffled 6 qt pan with 15-503 pick-up
      Go EFI 8 Fitech – w/Aeromotive Phantom Stealth 340 in-tank electric pump & Aeromotive 13305 regulator
      Crane Hyd roller 234/246 @ .050, 288/300 @ .006, 592/614 (1.65) 112 LSA
      Hooker SC 1 7/8 Hders, 3" X-pipe, mufflers, exhaust and Olds trumpets
      Be Cool Alum Radiator w/dual elect fans
      Tremec Magnum 6 speed (2.66, 1.78,1.30,1.00, .8, .63)
      McLeod – “street twin” clutch & SFI approved scattershield and hyd clutch
      Chevy 12 bolt posi 4.10 gears - rear end fully upgraded by Brian Trick - axel tubes welded to the pumpkin, Moser Axels, TA Perf girdle cover
      Rear Suspension: Hotchkis adj upprs, jegs lowers, CPP 2" drop springs 140 lb, UMI relocation brackets #4012 and UMI 1” chassis mount rear sway bar # 4047-xxx, QA1 single adjustable shocks on #4 setting for street
      Front Suspension: QA1 Pro Coil Over system 500 lb w/single adjustable QA1 shocks on #4 setting for street, AFX spindles, SC&C adjustable tubular upper arms -aggressive street set up, Global West tubular lower control arms, Hotchkis 1.5” Hallow sway bar w/1" metal welded in for better fit, SC&C Chassis Brace
      Hydroboost set up w/Baer 13” GT rotors for AFX spindles front, Baer 12” rotors rear, Hurst roll control
      Lee 800 12.7:1 1275 psi to match hydroboost and steering pump
      Factory AC w/upgraded lightweight compressor, new style condenser - R134 conversion
      18x8 Olds SSIs (NewGen 500s) Front rims 5.25" BS - 255/45/18 Nitto 555
      18x10 Olds SSIs (NewGen 500s) Rear rims 6" BS - 305/45/18 Nitto Drag Radials
      Stereo: Sony MEX-GS610BT Bluetooth/IPOD/2 way voice w/mic above steering column, front speakers = high output Boston Acoustics Pro Series 5 1/4” split channel – replaced Custom Autosound speakers inside the kick panels, flush mounted 5 ”” Bouston Acoustic CRX57 2 way speakers in the rear. Kicker 12" sub Comp RT loaded enclosure (one passive) with a 500x5 watt JL Audio amp kit.
      Slowly but surely moving along with the upgrades. Don't have everything in one thread so I'm starting one here:
      Joe Lincoln
      Lime Green 71 Olds 442 Convertible
      Upgrades thread: https://www.pro-touring.com/showthre...ible&highlight=
      Apr 2008
      Virginia Beach VA
      Joe Lincoln
      Apr 2008
      Virginia Beach VA
      Joe Lincoln
      Apr 2008
      Virginia Beach VA
      Joe Lincoln
      Dec 2008
      Lehigh Valley Pa
      Looking great. Keep us updated.
      1996 Federal Cadillac hearse
      1988 Eureka Chevy hearse
      dayton, oh
      i've been a big fan of this car for a long time. nice work Joe.
      future plans?
      dave.t
      74 Javelin AMX - stocker
      Washington, MO
      Reallynice!
      Apr 2008
      Virginia Beach VA
      Thanks Dave. Future plans are to get it back on the road. As you can see from the pics it's getting there but still a ways to go. Still need to finish the interior, brakes, front end alignment, test & tune, then paint & body. Added fiberglass fenders, front bumper, rear deck...lots of body panel line up and fresh paint to go. I'd like to get it back to the track by next summer...but that has been my goal for the last 2 summers. We'll see. I'll keep updating with pics here as it moves along.
      -Joe
      Joe Lincoln
      Apr 2008
      Virginia Beach VA
      Not many updates but have some new pics:
      glass fenders and new hood:
      left rear shot:
      another gauge pic:
      another engine pic:
      Joe Lincoln
      Lake Oswego, OR
      Coming along nicely. It's good to see another Olds on here!
      Lee
      1966 Cutlass
      The difference between truth & fiction: fiction has to make sense.
      Build Thread:
      https://www.pro-touring.com/forum/sh...ad.php?t=64470
      Oct 2005
      Toronto
      Quote Originally Posted by 71OLDS View Post
      left rear shot:
      another gauge pic:
      another engine pic:
      Way cool build, can't wait to see it when it's finished....
      Carbon Kustoms Limited
      A.K.A. Albert from Toronto
      Mt.Pleasant Pa.
      looks good.
      71 olds cutlass supreme convertible
      07 dodge ram
      96 monte carlo
      11 dodge challenger
      http://www.fquick.com/724TIM
      http://s297.photobucket.com/albums/mm206/724tim/
      Dec 2008
      Lehigh Valley Pa
      I am liking it more and more.
      Apr 2008
      Virginia Beach VA
      no progress but got a few more pics from different angles and views:
      rear view of wing and new bumper (no bumper guards)
      full driver's side view...can see baer new baer brakes front and rear:
      drivers side of engine compartment:
      closer pic of new gauges:
      hood brakets/hinges installed....stock screen will be added later...
      close up of Nitto 305/45/18 drag radials and new 12" rotors:
      Joe Lincoln
      LI,NY
      Love the car...beautiful color combo!
      Sep 2007
      Italy,Texas
      should have not posted that pic of the trans tunnel with that nasty looking hump for a shifter. Other than that I like it
      Oct 2005
      Toronto
      I'm just willing to bet we all have one spot on the car we'd really like to have done a little better,,,,, That said, the car is really super otherwise right.
      Lets celebrate the good stuff guys... Great build and I look forward to seeing videos of you driving it this coming summer hopefully...
      Miamisburg, Oh
      Something about that color, the white top and the ram-air hood with decklid spoiler is just RIGHT. Man I'd cruise that thing all night!
      69 RS
      LS7, T56 and other cool stuff
      Back on track in late 2020!
      Build Thread
      East Washington state
      Nice...
      LaMont Mulligan aka munster, leroy, mull, just don't call me late for dinner..
      My car is Therapy. 69 - Firebird into Camaro wana be. Sheep in Wolves Clothing. DSE tubs, Air Rides Airbar Rear susp., CPP Tubular CA's w/Shockwaves, Unisteer Rack&Pinion, RS Hideaways, Polished calipers, drop spindles, 4wheel disc, Be Cool rad, 18" Coddingtons Junkyard Dogs w/12"wide mod on rears, BFG KDW's 335/30/18 & 245/40/18 fronts. 383 Stroker, Edelbrock Vic Jr Heads and Manifold, lunati cam solid Roller, Pro-Magnum Roller Rockers, Demon, MSD Dist, 6AL, Thorely Tri Y ceramic coated headers. Converted to 68 dash. Moser narrowed 12 bolt and fitted for Airbar.
      Apr 2008
      Virginia Beach VA
      Thanks for all the kind words!
      as far as:
      ...this was an original M20 4 speed car. The tunnel and the hump had very little modification needed to upgrade to the Richmond 5 speed. Here's what it looked like in 1997 (date of first restoration) when the stock M20 came out:
      ...I guess it's not too pretty in either situation but it's not far from how it was originally even with the 5 speed in there. Also it will be covered by the boot and then the original 4 speed console. ...so no reason not to post a progress pic..in my opinion of course...but to each his own...
      -Joe
      Joe Lincoln
