Page 15 of 15 FirstFirst ... 5 10 11 12 13 14 15
Results 281 to 298 of 298
  1. #281
    Jun 2014
    Default
    You have a great looking coupe! I love the red and the Edelbrock wheels
  2. #282
    Jun 2010
    Houston
    Default
    Quote Originally Posted by rusty428cj View Post
    This is what I did today. I'm not finished yet but it's a start.
    I am about 90% finished putting the Dynamat in my '66 coupe. It is a lot of work !!
  3. #283
    Sep 2009
    Port Richey Fl
    Default
    I decided to mount the wiring behind the seat on the plywood board that came with the Mustangs to Fear trunk kit.
    I replaced the coil packs and plug wires but still have a lot to do under the hood.
    Rusty Gillis
    Former SS/FA & SS/GA NHRA National Record Holder
  4. #284
    Sep 2009
    Port Richey Fl
    Default
    We installed the Dakota Digital gauges awhile back but I never did get a photo. Now I need to get a battery installed in the trunk so I can see them in color!
    Rusty Gillis
  5. #285
    Sep 2009
    Port Richey Fl
    Default
    Mustang to Fear dash pad came in a long time ago and is a very well made dash pad. Now if I can only get the wiring straightened out under the dash I can install it.
    Rusty Gillis
  6. #286
    Feb 2013
    Default
    I always forget how small these engine bays are, even the 2v looks kind of tight! Good work bud!
    Ridetech Suspsension
    Tech Specialist
    Phone: 812.481.4734
    Project Fox
    1979 Trans Am
  7. #287
    Sep 2009
    Port Richey Fl
    Default
    I ran out of room at the shop so I moved this to my house and started working on it again on the weekends.
    I had a hard time finding a master cylinder that would clear the cam cover and did a search on line and found this Bronco II master cylinder and it fits.
    Rusty Gillis
  8. #288
    Sep 2009
    Port Richey Fl
    Default
    I have been using a board to hold up the deck lid after searching I found these struts from Mustangs Unlimited
    My intake was cracked while I was replacing it I found a good place for the AC valve
    New intake
    Next problem I had was none of the brackets for the alternator would work so we had to cut and modify the first one to fit. Sorry no photo
    I bought stainless steel transmission cooler lines for the AOD but they didn't fit so I made my own
    I ordered a set of Vintage LEDs taillights
    Rusty Gillis
  9. #289
    Sep 2013
    sw Kansas
    Default
    I've missed this build for some reason???? Just in case it's of value to you, there is numerous wiring diagrams on the internet to change from coil pack to coil on plug to clean things up some. Cars looking good.
  10. #290
    Sep 2009
    Port Richey Fl
    Default
    I painted the headers. It's tight but they fit. I want to get it running and check for problems before I get them coated.
    Rusty Gillis
  11. #291
    Nov 2017
    Default
    Did you make metal ductail ends or did you just bond those in place and fill the seam?
  12. #292
    Sep 2009
    Port Richey Fl
    Default
    Quote Originally Posted by JRANGER View Post
    Shelby convertible fiberglass end caps bonded to the quarter panel.
    Rusty Gillis
  13. #293
    Sep 2009
    Port Richey Fl
    Default
    After a little modifying of the headlight buckets I got the headlights with built in turn signals to fit.
    Rusty Gillis
  14. #294
    Sep 2013
    sw Kansas
    Default
    Sure cleans the front up.
  15. #295
    Sep 2009
    Port Richey Fl
    Default
    Rusty Gillis
  16. #296
    Sep 2009
    Port Richey Fl
    Default
    I hooked up the battery in the trunk (I still need to hook up the ground cable to the engine) to see what works. The Ron Francis trunk mounted battery kit has two ground gables one small short one that I have going to the body and a large long one that they want mounted to a bell housing bolt. So far the AC 3 blower speeds work, taillights, turn signals, and headlights.
    I have a problem with the lights in the dash flashing when the key is off and the steering column harness is hooked up.
    Rusty Gillis
  17. #297
    Sep 2009
    Port Richey Fl
    Default
    I installed the battery ground cable from the trunk mounted battery to the engine block and cured most of my electrical problems.
    Vintage LED turn signals are working
    Headlights and turn signals are working
    Rusty Gillis
  18. #298
    Sep 2013
    sw Kansas
    Default
    I'm a huge fan of the 67-68 dash. Those gauges are a very good addition. In reading your last couple of posts, I'm aware that most of us have similar stories to tell. Not a big deal, it is what it is.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
