    Page 12 of 16 FirstFirst ... 2 7 8 9 10 11 12 13 14 15 16 LastLast
    Results 221 to 240 of 302
    1. #221
      SF Bay Area
      Wow, can't wait to see how it looks when you put it all together!
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
    2. #222
      Sep 2009
      Port Richey Fl
      Quote Originally Posted by 1fststang View Post
      Looks real good. your making steady progress. I am building a 67 Fastback and thinking about adding coilover suspension front and rear. Just curious what your thoughts are on the coilover kit you installed in the back on your project? I think that kit is about the only real bolt in kit for a 67. I wonder if it will gain me enough clearance compared to the leaf spring rear for me to think about adding mini tubs.
      It is a bolt in but we welded it in place. It will give you a little more clearance. You will have to modify the frame rail if you mini tub.
      Rusty Gillis
      Former SS/FA & SS/GA NHRA National Record Holder
    3. #223
      looks great!!
      Jul 2010
      OREGON
      Wow that red really pops...
    5. #225
      Sep 2009
      Port Richey Fl
      Ready to come out of the booth for wet sanding
      After wet sanding with 400 Brian taped again and it is ready for 3 more coats of clear
      Rusty Gillis
    6. #226
      Jul 2011
      NJ
      Country Flag: Ecuador
      I think i spotted a 66 fastback somewhere in there! lol
    7. #227
      Sep 2009
      Port Richey Fl
      Six coats of SPI clear after it sits a few days we will start wet sanding than buff
      Rusty Gillis
    8. #228
      Sydney, Australia
      Country Flag: Australia
      Wow.....nice! Even the masking is awesome!
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
    9. #229
      Hey Rusty, I am patching the cowl on my 67 Fastback and need to replace the inner kick panel area. Trying to decide to splice in(butt weld) in front of door post or remove the dash and replace the entire panel. How hard is it to remove the dash and get it back in exactly where it was located. Looks like two tabs, one on each side is spot welded to the lower kick panel side and then on the ends in the windshield post area. I was thinking of drilling a few 1/8" alignment holes to aid in getting it back in just the right position. I also have to make a couple patches where the pillar area overlaps the lower kick panel in the upper corner. Its thick metal and unique shape. Thinking to make it by cutting it in to 2 or 3 pieces that will be easier to shape and then weld together. I think I saw some pics where you guys fixed this area to. You by chance have the link or can post? Thanks
    10. #230
      Houston, TX
      Rusty,
      I've seen your work over on s10forum.com(Current Performance LS-S10) and now over here. You're s%^! is awesome!!! That bodywork and paint is amazing and like Leigh said, even the mask is off the charts. Love watching your updates too. Really lets me see how a reputable shop would do things. Maybe with some work I can transfer some of that to my home garage. Keep it up!
      Asa Walker
      Houston, TX
    11. #231
      Sep 2009
      Port Richey Fl
      If it is not rusted out by the dash I would butt weld the side panels we have done that on a couple of Mustangs and it is a lot easier than removing the dash
      Can you post a picture of area you are talking about? We have repaired the hinge area a few times.
      Rusty Gillis
    12. #232
      I have the cowl removed and the top portion is in really good shape. I have the lower cowl end patch and th the lower kick panel area to replace. The upper corner l needs some attention and I don't have replacement pieces for this area so I guess I need to fab something up.
      Having trouble uploading pics. Will figure it out and get a couple posted.
    13. #233
Size:  88.8 KBName:  DSCN1550.jpg
Size:  95.0 KBName:  DSCN1562.jpg
      Here is the bad area upper right corner. The new lower kick panel goes up under this piece which I am replacing as well. Will probably just butt weld it in front of the door jamb. The area under this upper piece is rusty to so I will will probably need to make a patch underneath before i weld this in. Last picture is first attempt at a patch for this area. I won't weld it to the upper part until I remove and replace that. To replace the very bottum piece I may need to remove that whole piece that the door bolts thru to get at it good. thoughts?
    14. #234
      Sep 2009
      Port Richey Fl
      The body was wet sanded with 1000,1500,2000,2500.
      One side is buffed still needs to be polished
      Rusty Gillis
    15. #235
      Sep 2009
      Port Richey Fl
      Brian is polishing the body so we can get the sheetmetal back on. It takes up a lot of room in the shop when you have everything on stands.
      Rusty Gillis
    16. #236
      Sep 2009
      Port Richey Fl
      We have the doors, deck lid and taillights installed.
      Rusty Gillis
    17. #237
      Dec 2010
      Apex, NC
      Looks great! You prepared to fly out and spray mine?
    18. #238
      SF Bay Area
      Wow, this is coming together very nicely. Great job!
      chunger
      '68 Ranchero 500
    19. #239
      Oct 2011
      Katy, Tx
      Wow that car is coming together now. SMOOTH, like it's still wet...
    20. #240
      Sep 2009
      Port Richey Fl
      The rear bumper was wet sanded now Brian is buffing
      Rusty Gillis
