      Dunwoody, GA
      SBC fast burn heads and headers
      Is there any reason a pair of SBC headers with 1-3/4" primaries won't fit the fast burn heads? I've never dealt with the fast burn heads before and just want to make sure before I assume they will.
      Trey
      ~ Jon Hammond
      Aug 2005
      Patterson, NY
      I think the FB heads have "D" shaped exhaust ports. I don't know if that matters or not.
      Jason Scheer
      Nov 2007
      near Orlando
      The exhaust ports on Fast-Burn heads are positioned a little higher than the regular bolt pattern location. If you can get a picture of F/B header gaskets compared to stock header gaskets you will see the difference. A few people have said that you can run a standard port header. I don't know if the restriction/misalignment of the port negates the advantage that the F/B heads provide. I didn't realize how few headers were available when I purchased my heads. Edelbrock makes F/B headers for some F-bodies. Otherwise Lemons or Stainless Works can custom make them for your application.
      RagRat
      Chris Costa
      Tallahassee, FL
      Hedman makes a mid-length header that has the fast-burn port. (My '72 has a ZZ383)
      I ended up getting them because I wanted a good fit and didn't want any ground clearance issues. They won't clear a clutch pivot though, so if you have a stick you'll need to run a hydraulic clutch.
      The other option I've heard about is slotting the flange on a 3/4" header and sliding it up a little.
      -Rich-
      '72 Camaro RS/SS350: (ZZ383-TH350) Under Construction
      '88 IROC L98 (TPI 383-700R4)
      '70 VW Beetle (1600cc-Auto-Stick)
      '92 Camaro RS (Carbed 350-TKO)
      '04 Chevy Tahoe-Daily Driver (5.3-4L60E)
      '29 Ford Sedan (Carbed 350-T5 ...Grandpa's RatRod)
      Newbury Park, CA
      Standard headers can work with Fastburns but the flange bolt holes will need to be slotted approx 3/16" to align the top of the port to the top of the header tube. A 1-5/8" Hooker Super Competition header will also work but the excess weld on the inside of the tube should be removed as well.
      If memory serves it's a 1470 Felpro gasket.
      Nov 2010
      Vancouver, BC
      Hello Guys
      Is their any issues with spark plug clearances? I will be attempting to fit an old school set of 1 3/4 Hedmanns to my fast burn heads. Any info would be much appreciated.
      Thank you, Mike
      Nov 2010
      Vancouver, BC
      Update on fast burn heads
      Hello friends
      I thought i would update you with the info i found out about this header install. Yes Carlc is correct about port placement and his recommendation about slotting the bolt holes is spot on. However i have a tendency to over analyze things ( a lot of us gearheads are like this..lol). I currently have the heads off the car and fully disassembled, this allows me to visually see the port match looking up through the exhaust seat. My fast burns are the early style and my research says exh. port is .200 raised so its actually a bit more than 3/16. What i did was to grind the header holes downwards and keep an eye on my progress with a vernier caliper measuring the slotting as i progress. when the slots get close i then fit the header to the head and check the positioning. This prep work will pay off with a much easier install, all you have to do is pull headers up till they stop and tighten in place. You can even go as far to spot weld two holes so the slot becomes more of a permanent round hole. this will not allow the header to drop out off alignment. As we all know headers do get a bit loose on there "break in" of the gaskets and require retightening. There is always a chance they could slip down so the welding up of a few slots is added insurance. ( anal i know but some of us lose sleep over stuff like this..lol). As far as spark plug clearance goes, it all looks very good with #3 cylinder a little tight but still has an air gap between boot and header tube. These are Hedman 1-3/4 tubes purchased in 1985 (early F body). I might just give it a little tweak (dent) for a bit more clearance. I'm happy I can make these old school headers work, i'm a frugal car guy, like a lot of us.
      Cheers and take care guys!!!
