    Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 61 to 80 of 115
    1. #61
      Will you be offering these for any other applications? Like maybe a '70 Chevelle?
    2. #62
      Fort Worth, Tx
      Quote Originally Posted by BMR Fabrication Inc. View Post
      Ahem!! The 65's would like to know too.
    3. #63
      Dec 2009
      Butte County, CA
      let me know the pricing too :D
    4. #64
      May 2009
      X2 on the 70-72 chevelle application!
      I will be one of your first buyers if that happens.
      I also woulnd't mind a rear deck with the 6.5 mid and 10in sub setup.
      Keep up the good work and keep us posted on new products!
    5. #65
      Merritt Island,FL
      I just happen to have a 70 Elcamino in the shop right know.
      Looks like I'll be fitting some kicks !
      Second gens are coming too!
      Check out my web site.
    6. #66
      May 2009
      SWEET!
      Ill keep an eye on this thread for the release of the a-body kicks!
      Will the kicks work with vintage air equipped a-bodys?
    7. #67
      Feb 2010
      Modesto California
      question?
      would these fit a 68 Firebird?
    8. #68
      Jul 2008
      antioch,ca
      do they make these with no hole at all for 68 camaro
      David Badley
    9. #69
      Aug 2003
      Wanatah, Indiana
      Installed mine in a 69 Camaro. The fit was great, contours were dead on. I only have 2 inputs on these panels, first if you have vintage air installed you might want to drill the holes before you install the ac unit. The use of a right angle drill might have saved some headaches. The other is the holes for the midrange speakers had to be opened up for the choice of speakers I chose. I wanted matching speakers for my already purchased rear 6x9's.
      I do have to say that the customer service was great. My parents ordered these for me at Christmas and they never used "never heard of " paypal. They talked my mom through this and said if she had any questions to call them back.
      Thanks again for a great product.
      Mark Antrim
    10. #70
      Merritt Island,FL
      Quote Originally Posted by Bob's68 View Post
      question?
      Yes they do !
      Brian
    11. #71
      Merritt Island,FL
      Quote Originally Posted by 676869addict View Post
      Sorry we don't.
      Brian
    12. #72
      Merritt Island,FL
      Quote Originally Posted by Mark Antrim View Post
      Mark Antrim
      Mark,
      Glad you like the panels!
      Brian
    13. #73
      Sound
      I am leaning towards these, can anyone tell me how does the system sound? I wander how hard it would be to make panels that bolt to the undersider of the dash that follows the contours of the AC, parking brake etc, to prevent the sound waves from being absorbed under the dash?
      Tony H.
    14. #74
      Dec 2009
      Butte County, CA
      pricing for a 67 with vintage air unit please?
    15. #75
      Jul 2007
      Quote Originally Posted by 67speedfreak View Post
      Screamin' Performance is proud to offer these custom kick panels for 67-69 Camaros.
      They fit a 6.5 in mid driver and a 1in tweeter. These were designed around Boston acoustic pro speakers but will fit most others.
      Awesome work. I am pretty sure I'd like a set of these, but want to verify a few things as I won't be using the Boston Pro's.
      I assume that these are setup for the Boston Pro60SE
      http://mobile.bostonacoustics.com/ma...ro60SE_man.pdf
      My questions related to what will fit:
      1) What is the dimensions of the grill you are using and is there any extra space for a slightly larger speaker. I notice on the BPro spec sheet their grill is 7" (177mm).
      2) They also show 37mm of clearance for the driver and its xmax, is the grill you are supplying comparable?
      3) The Pro60SE are 2.5" (63mm) deep. Is there any extra clearance for a deeper driver? (80mm would be my target)
      4) The basket diameter of the speaker is 5.25"(133mm), how much extra clearance is there around the driver? (for instance would 145mm fit?)
      5) The tweeter cut out shows a 1.75" (46mm) cutout, with a flange of 2.5".
      Other general questions:
      6) Where are the tweeters aimed to? (my goal here is to understand how far off axis from the drivers ears I need to plan as I pick my drivers)
      7) If you do not run the protective cup, how much of the elements do you think the driver will be exposed to?
      8) To install the panels does it require that you bend them or do they go in even if they were stiff? (I plan on adding some mass and deadener to the panels to further reduce any resonances)
      Sorry for all of the questions, although hopefully they will help others as well. As an aside the reason for my questions are that I have a large collection of 7" (175mm) drivers that I would like to audition in the car before selecting which ones to actually use. In the non-car world this is a very common size although less so in the mobile world. Considering I am a midbass nut having more dynamic capability both from Xmax and from Sd is something I'd like to have. If they won't fit, it will mean I will just have to adjust and go with a more normal 6.5" driver, but I wanted to ask as using what I have already is of obvious benefit.
      Thank you.
      Sean
      edit: for a 69 Firebird
    16. #76
      Merritt Island,FL
      Quote Originally Posted by dlouie87 View Post
      Kick panels with cans are $325.00 plus shipping to your address.
      Brian
    17. #77
      Merritt Island,FL
      Quote Originally Posted by SeanH View Post
      Thank you.
      Sean
      OK, That is alot of info but I will try and answer your questions.
      The grill we are using measures 7"
      The close out cans are 3.5" deep for speaker clearance
      Yes I believe there is extra clearance around the driver
      The tweeters are angled so the the drivers faces the passenger and the pass faces the driver.
      The cans seal off the kick opening from the elements. Without them water will leak in when it rains.
      The panesl should not require bending to fit, we spent alot of time on fitment.
      Brian
    18. #78
      Jul 2007
      Thank you for the reply. One bit of clarification, does the inside of the grill measure 7" or the outside?
    19. #79
      Merritt Island,FL
      The outside.
      Brian
    20. #80
      Feb 2007
      USA, TN
      Any idea if these will fit a 3rd gen Nova? That part of the car is very similar to a 1st gen Camaro.
