Results 21 to 40 of 303
06-30-2009 #21
Sure, I picked this up from a couple other forums, because I was getting an incredibly bad drone from the previous cam that I had.
The idea being that you Tee off the tail pipe a dead end section of exhaust tube 50% the length of the tailpipe.
The resonator then is supposed to cancel out the droning sound waves coming through the tail-pipes.
You should also make the resonator pipes a slightly different length from each other, so that it also reduces harmonization.
Does it work. Yes absolutely cancels 80-90% of exhaust drone. Does not rob any horsepower.
The down side, if any, is it really knocks down the exhaust note. Mine sounds like a beast with them off, and more like a modern day performance car, with them on.
But the car was built for long performance cruising, and does have a good sound system, so it's really the right thing to do.
