    Page 2 of 2 FirstFirst 1 2
    Results 21 to 35 of 35
    1. #21
      May 2009
      Centennial, CO
      Found those clamps @ Northern Tools
      Here you go $10 for 4. Not as good a deal as HF but I couldn't find them from HF online.
      http://www.northerntool.com/webapp/w...1757_200381757
    2. #22
      Jan 2010
      dexter mi
      I just thought I might add a little trick . Before you notch down that weld on a warped panel . Get yourself a hammer and dolley . Hit just the weld . The weld is the only thing that shrunk . You can also use a few tack welds to shrink up an area if it "oil cans" .
      I love the tape templates ! Great post
    3. #23
      Ramona, Ca. San Diego area
      Great tip.
      What I do to is hold a piece of metal behind the hole you need to patch or repair and use a can of black paint and lightly fog over the hole. This will leave a pattern on the new piece behind the hole. Then you cut along the paint line.
      67 Camaro convertible (Jinx)
    4. #24
      Sep 2008
      Kathleen, GA
      definitley a "why didnt I think of that " idea..spray paint is also a very good idea....excellent tips !
    5. #25
      Oct 2008
      Durham,NC
      Spray paint?
    6. #26
      Feb 2009
      muggy midwest
      great tip! I do a lot of electrical experiments and through that I became aware of super strong rare earth magnets and those are what I use to keep small patch panels tight and flush while butt-welding. They work great too!
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    7. #27
      Nov 2010
      Great Tip!!!!! Thanks so much
    8. #28
      Feb 2010
      Austin, TX
      Have always used the tape method, never thought of spray paint. Another great way of getting it done.
      Nick
      68' Camaro RS/SS - Current Project
      72' Nova SS
    9. #29
      Mar 2012
      Des Moines, Iowa
      One thing I suggest is instead of sharp cornes use round ones as much as possible. You produce less heat in round corners then you do in sharp corners of patch panels.
    10. #30
      Northern Colorado
      Quote Originally Posted by cadwiz View Post
      Exactly. Round those corners off and don't be shy. Think about how the corner piece of the lasagna is always more done than the casserole that's cooked in a round dish. That hard corner is subject to a lot more heat than if you round it off with at least a 1/2" radius.
      Another point that someone brought up is to hammer and dolly the weld seam. After you weld that piece in, dress the weld till it's about flush with the patch and surrounding surface. The heat affected zone (HAZ) is where all the shrinkage has occured. On firewalls and floors where there is lots of shape and contour to maintain strength, the shrinkage will be almost unnoticeable. On surfaces that are flatter, the shrinkage will cause oil canning. Hammer and dolly on the seam only to stretch that HAZ back to a more relaxed state. Careful not to stretch too much, because you can go too far the other way. Firewalls and floors are great places to practice this technique for more delicate, flatter panels.
      Adam Moyer
      '69 Cutlass "S"
    11. #31
      Oct 2012
      Country Flag: Australia
      Literally just seeing that tape idea has opened my eyes.
      I thought metal work would be harder than I thought to make weird shaped patches, but if you are using a light gauge metal, you can get a rough shape by shaping the new metal over the damaged/rusted metal, then use the tape method after cutting a patch section to transfer the shaped metal in.
      That is just a way I thought of doing it just then, and I am sure there are more "professional" ways out there.
      But that just solved one of my little brain barriers. lol
    12. #32
      Mar 2012
      Carlisle, PA
      I wish I would have seen this idea about 20 years ago. I knew about the paint one.
      63 Biscayne
      Schwartz Performance Chassis
      My build thread: https://www.pro-touring.com/showthre...ht=#post916553
    13. #33
      Jul 2012
      Louisiana
      i have used the paint method before, but never thought of the tape method. i think its a better way to go. here's another if not mentioned before, use small magnets to hold the panel in place while tack welding only, but remove them after as they will disrupt the electrical wave pattern and mess up your weld.
    14. #34
      May 2012
      nice work (smashin my head)
    15. #35
      Oswego il
      Another quick tip, get a foot of pipe in several diameters, weld a flat plate to it to clamp in your vice. Quick hammer forms for putting some shape into a patch.
      I also ground, filed 3 1 foot long sections of the edge of my welding table to different radii. 1 sharp, 1 medium, 1 large. Makes real quick bending simple with a couple clamps and gradual hammering.
      I have a couple of hardwood 2 x 8 sections with male or female "beads" router'd into them. Work well to replicate the form when patching. I use flat plates ground to radii, welded to a short pipe, hit with a hammer to form. Pipe has a slot ground in, with the plates slipped into the pipe before welding. You don't strike these very hard, Gradual forming into the beads, making sure it lines up.
      trusty piece of railroad rail about 18 inches long, has different shapes on each corner, my town had a large railroad repair yard for about 70 years, so there's a lot of this stuff around, not sure where to get it now.
