    Results 21 to 40 of 57
    1. #21
      Atlanta GA
      niiiiiceee!!!
    2. #22
      Fontana, CA
      Quote Originally Posted by Samckitt View Post
      So the only difference in the 4.8 & 5.3 pistons is it raises compression?
      Yes. 4.8 Pistons are flat top. 5.3 are dished. They are the same bore. easy and cheap swap.
      Nick R.
    3. #23
      Oct 2007
      Shawnee, KS
      Same weight or is a rebalance needed?
      Shannon
      67 Camaro - Finally getting to BUILD it.
      Camaro Build -> HERE
      Our Drag boat blog and videos HERE
    4. #24
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by 67CamNKC View Post
      We rebalanced.. I would doubt they would weigh the same (flat top vs. dish)
      1968 Track Rat Camaro:
    5. #25
      Mountain View, CA
      any photos of those coil mount thingys?
      True T.
      My blog
    6. #26
      Eastern Virginia
      If someone was to build this engine, about what would it cost?
      Scot
      86 Monte SS
    7. #27
      Eastern Virginia
      What is the differrence in a 5.3L engine from a FWD car compared to the truck one?
      Scot
      86 Monte SS
    8. #28
      Chesapeake, VA
      Sure, if you tried hard enough you could get that hp out of a 327. It sure wouldn't have that torque curve, though. A person could have a lot of fun with that under the hood.
      Cars are meant to be driven.
      John B
    9. #29
      Eastern Virginia
      Quote Originally Posted by jaybee View Post
      OK I am confused. What do you mean the 327 wouldnt have that torque curve? According to Steve1968ls2 these numbers are coming from a 5.3L/327.
      Scot
      86 Monte SS
    10. #30
      Newbury Park, CA
      A Gen1/traditional 327.
    11. #31
      Eastern Virginia
      Ah.
      Scot
      86 Monte SS
    12. #32
      livermore ca
      so by taking the flat tops out of the 4.8 and putting them into the 5.3 you up the compression because they 5.3 are dished?
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
    13. #33
      Fontana, CA
      Si senor.
      Nick R.
    14. #34
      Oct 2008
      Roseville
      Quote Originally Posted by Damn True View Post
      Nice numbers!
      I would like a pic also.
      Are they like these?
      http://www.automotivedesigneng.com/p...coil_pack.html
    15. #35
      Dec 2007
      norman ok
      besides used what other options on pistons are out there?
    16. #36
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by camaro2nv View Post
      Nice numbers!
      Working on it.. I forgot them at the shop. They were made by Cris over at JCG restorations in Oxnard.
    17. #37
      May 2008
      South Jersey
      Quote Originally Posted by jilge71 View Post
      They may not all make ones for 5.3's but they all have them for other LS' - Diamond, Mahle, Wiseco, JE, Probe, CP, SRP
      Nick
      '67 Chevelle 350/th350..... soon to be all aluminum 5.3
      '73 Chevelle 4.8/th350
    18. #38
      Jul 2003
      Anaheim Hills, CA
      Turn key does sell the pistons new and I don't think they are very spendy.
      Other than that.. used. You could do the same deal with fancy aftermarket pistons but that would defeat the point.
    19. #39
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by lt1chevelle View Post
      Yup..
    20. #40
      May 2008
      SoCaL-Pico Rivera
      Steve will the lq9 flat pistons work as well? is the reason the 4.8 were listed is for budget build?
