03-14-2005 #1
NEED HELP! Air filter wont fit on procharger on engine..
Test fitting the procharger on my engine.. there is not enough room for the air filter as the master cyl is only 2 inches away from the inlet of the supercharger.. along with the metal brake lines..
What can i do for a airfilter..?
Project JUST-N-SANE
84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
03-15-2005 #2Got any pics from the other side? I helped make a 'glass airbox for a mustang in the same situation; we just split the inlet & went around the MC.
03-18-2005 #3I ordered a 90 degree hose and a tube that hopefully will work..
Project JUST-N-SANE
04-02-2005 #4If the 90 bend doesnt fit , start looking into custom fabbin up something that will. Maybe a hard 45 will clear your master. Look st some custom header designs to get some ideas....
ProTeal55
1955 Chevy Bel-Air 2 Door Hardtop
Member: Half Fast Chicago
http://www.halffastchicago.com
