    Page 2 of 2 FirstFirst 1 2
    Results 21 to 25 of 25
    1. #21
      May 2001
      Mesa, Az.
      Matt,
      It was cool shootin the stuff with you in Sumerset KY. We ended up plugging a fuel filter and taking the fuel pump out on our LS7. Bummer. Oh well. Wish I could help you with the ETC, have you tried LS1Tech?
      Phillip
    2. #22
      Jun 2006
      NW burbs IL
      Home track best time reduced by 2.5 seconds
      So after all the upgrades this winter I finally made it back to my home track. The car feels neutral in turns right now. There is still more in the car, I just need the time to tune the suspension ( stiffen up the sway-bars and shocks to see how she reacts ) and engine fault code problems. Here are some pics a friend took on Saturday.
      She still has some lean, which I'm hoping to even out. As I pushed the car later in the day, I was getting a wash board effect as I was running around the corner I'm entering in the second pic.
      The fuel vent system I fabricated over the winter was still allowing some fuel to vent out when full. While I had the tank out I added an 90* AN elbow on the tank and bent up a line to effectively put a loop in the path to the reservoir and overboard filter. Prior to this I would smell fuel when it vented and or have it leak out. The original setup had a brass fitting pointed straight toward the front of the car. After wailing on her at the track with a full tank, I have not experienced any odor or venting to the ground. ( fingers crossed, I think it worked )
      Here is a pic of what I added:
      Matt
    3. #23
      St.Anne Il
      thats cool to hear..are you driving it to RTTH?..is the wife going along?
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
    4. #24
      Jun 2006
      NW burbs IL
      Quote Originally Posted by dropit69 View Post
      Yes, on the street tires. I may try and bring along the race tires. The wife wont be driving down, I can barely handle that length drive in the car.
      Matt
    5. #25
      Michigan
      Kudos to you for flogging such a badass car around the road course! Some day I hope to do the same.
