Results 1 to 17 of 17
03-08-2009 #1Starting The Transformation
- Jan 2008
- Felton, DE
- 346
DEemon tuning issues, CANNOT get it to lean out, running wideband 02 whats wrong?
I finally got around to remove my holley 750 and putting on my speed demon 750 dp. I cant get the damn thing to lean out. I am thinking it may be a power valve issue as i my laptop is in my truck at work and i can check vacuum but i am running the same power valve as before.
I disassembled the whole carb when i got it. metering blocks were switched but fine. Carb had a 6.5PV, 75 primary jets and 82 secondary jets. I could get the idle AF down to 12.5:1 or so with this setup. but WOT would peg at 9.6:1 and cruising would be around 11:1. I tightened the 4 corner screws all the way in and backed them out only 1 turn. They are barely out.
Today after fiddling around with the carburetor a little bit, i lowered the float bowls (to bottom sight glass marker) didnt do anything. I replaced the primary jets with 71s, and the secondaries with 75s and it now runs RICHER! i have on idea. I'm idling at like 11.8:1 at idle same 9.6:1 at WOT, and 11.5:1 on cruise (cruise seems to have leaned up a bit). I am testing this about a half hour apart engine at same 180 degrees, air temp is about 70-75 today i am at sea level.
The carb does have idle EZ which i am unsure of what it does so i am going to go fiddle with that for a while. The rockers i just adjusted today (re-torqued them down and thread locked them in place) didnt change anything but i just wanted to be sure.
What do you guys think? Before when i had the vacuum gauge on the car it read about 6psia vacuum which is about 12Hg. Any ideas as to what could be causing this carb to run so lean? All of the holes looked right in the metering plates, this exact carb was drynoed on a 530hp ford 331 before. I am just stumped.
1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
1978 Datsun 2+2 - 6.0L LS1 swap in progress
1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
http://www.myspace.com/shawnmacananny
