Results 1 to 20 of 37
    May 2006
    Ontario, Canada
    Mark VIII & SPAL V3
    Is anybody using a Mark VIII fan with a SPAL V3 controller? I know the Mark VIII can draw some serious current, and I see the SPAL's highest fuse rating is only 30A. Is it safe to install a higher amperage fuse without fear of damaging the controller? What fuse do you use if you have this same setup?
    I know the new model has built in protection for overcurrent, but I just want to make sure it's capable of operating with the high power Mark VIII fan.
    Erie, PA
    I will be using that exact setup, waiting for delivery of the fan right now. If you do a search on this site, the Spal PWM is good for 50A and you can safely use a 40 A fuse. The Mark VIII draws 33 A at full load...
    Andreas
    www.fgmcc.com
    May 2006
    Ontario, Canada
    Thanks for the reply. I have read that, but just wanted to confirm this from people that have actually used the setup that the in rush of the Mark VIII isn't too much for the controller to handle (I've read anywhere between 70-120A). Sounds like gmachinz uses this setup almost exclusively though, so I assume it's fine.
    Any suggestions on where to buy a standard size fuse rated at 40A? The largest I could find was 30A - looking online, it looks like The Source (Radio Shack) might carry some.
    Erie, PA
    I did get a whole box of 40A fuses at NAPA. Maybe they don't carry them all time?
    The PWM controller will make the Mark VIII fan switch on with 50% power only and then ramp up to 100% as needed. That should help reduce the initial Amperage spike, I hope!
    Andreas
    www.fgmcc.com
    May 2006
    Ontario, Canada
    Yes, the 50% start on the new V3 models should keep that spike down quite a bit. The old models used to give a 100% kick to get the fans moving, which defeated a large advantage of having a PWM controller.
    Thanks, I'll check my local NAPA for the fuses - IIRC it was Canadian Tire that I had looked at before.
    May 2006
    Ontario, Canada
    I'll have to play with it more, but so far - not good. The fan will run for a short while, then kick off and flash an error code #2 (fan not recognized). The last time I tried it last night it was flashing what I believe was a code 2, followed by a code 4 (over current).
    The controller is designed to turn off if there is a 25A draw after a certain amount of time... which is not going to be uncommon with the Mark VIII fan. In short I don't think it's going to work, in which case I will go with a simple relay setup with perhaps an adjustable t-stat switch.
    Erie, PA
    Did you try to use the low speed wire of the fan (middle) and run it with that?
    My plan is to wire the high-speed wire through a separate 75 A relay switch through the PWM...
    Andreas
    www.fgmcc.com
    Huntington Beach, CA
    Only the early model Mark VIII fans had two speeds. I'd say the majority of Mark VIII fans on the market will have two power terminals but both are "high" speed.
    Erie, PA
    So this famous info that is alll over the internet is wrong?
    93-96 use p/n F3LY 8C607 A @ 245.80
    The 93-96 spin 1100 rpmson low and 1850 on highspeed.
    97's use p/n F7LZ 8C607 AB @ 196.23
    98's use p/n F8LZ 8C607 AA @ 140.11
    The 97-98 spin 1800 on low and 2225 on high.
    http://www.dfwstangs.net/tech/markvi.../markviii.html
    Andreas
    www.fgmcc.com
    I've read here on this site many times that people don't have 2 speed Mark VIII.
    The Mark VIII fan I personally bought also goes the same exact speed no matter which terminal you use.
    Erie, PA
    oh ok, guess I will have to see what version I have once I wired it up...
    Andreas
    www.fgmcc.com
    Henderson,NV
    Take a battery and two wires and you have it figured out.
    Todd
    May 2006
    Ontario, Canada
    My Mark VIII works off both terminals, but I am unable to tell if they are actually different speeds (the wire gauge is heavier on one connector though, which would lead me to believe that is a high speed wire) since the SPAL won't run them long enough to tell.
    In short, I don't believe the SPAL V3 can handle the current draw of a Mark VIII fan. Here's some info for those interested:
    It's still relatively cold here, so if I start the car and let it warm up with the fan connected, the fan will kick on at the required time and maintain engine temp at what is surely 50% fan speed or slightly higher. However, if the engine is turned off even for a few seconds and the temps climb a touch, when I try to restart the car, the fan comes on, tries to ramp up to an appropriate speed somewhere between 50%-100% and kicks off after a few seconds. Sometimes it will spit out a code 2 (fan not recognized), and other times it will give a code 2 & 4 (fan not recognized & overcurrent).
    I was leary of whether or not it would work as we all know how much current this fan draws, but I know Jabin here uses this setup almost exclusively, so I figured I'd be ok. The manual states the controller will kick off if the fans draw >30A for more than a specified amount of time (ie allow for spike at ramp up only), so I can't see how this controller could ever handle the Mark VIII. It looks like I'll have to just sell the SPAL and go with a simple t-stat/relay setup.
    Erie, PA
    So which wire do you use for the SPAL unit, heavy gauge or lighter gauge?
    Are you using a SPAL temperature sensor?
    The earlier SPAL units did not have the overcurrent protection, this is new with Version 3. I find it hard to believe that the MarkVIII fan pulls more than 30 Amps continously at 50-60% load, when the reported 100% load is 33 Amps
    If Version 3 does not work, maybe you can use the brown wire to trigger a 70 Amp relay. Then the SPAL unit at least is still a temperature on/off controller...
    Andreas
    www.fgmcc.com
    May 2006
    Ontario, Canada
    I've wired it with both the positive wires - seemingly no difference in how it acts either way.
    You could have the SPAL control a relay as you've mentioned, but if you are going to do that, I'd just get a temp switch or adjustable thermostat and remove/sell the SPAL controller. Leaving it in place makes for an awefully cumbersome and expensive temp switch.
    It's the grey wire you'd want to use for that purpose - the brown wire is for a status output (to an LED).
    Erie, PA
    The gray wire only kick in at the high temperature setting, the brown wire (status light) kicks on at low temp setting
    I will let you know what happens with my setup once I get it going...
    Andreas
    www.fgmcc.com
    May 2006
    Ontario, Canada
    Yes, but if you are only using it as a switch to turn on a relay, it doesn't matter as you would only have one temp setpoint.
    That being said, I don't think either way would work since the controller would spit out an error code (#2) with no fan connected directly to it. This would cause the status light to blink... and in turn make your fans turn on and off with the blinking light. If you connected another small fan directly to the controller, and used the Mark VIII as your secondary fan, you could make it work, but that would be an odd setup.
    So your only real options (if it doesn't work for you either) is to find another way to control the Mark VIII, or get another fan. Please do post back with your results once you get a chance to try it out
    Erie, PA
    Good point
    Andreas
    www.fgmcc.com
    Walton, NY
    I've had a lot of issues with my SPAL controller. How do you tell which version you have?
    May 2006
    Ontario, Canada
    Quote Originally Posted by woody80z28 View Post
    Join the club...
    The new V3 model is much larger than the older models. I'm not sure how to tell the difference between the first two versions, but I think the wiring differed slightly. I went through two of the older models. I don't think there is anything wrong with my V3 model, it just can't handle the current pull of a Mark VIII fan. For reference, I borrowed a clamp-on meter from work and at 12v (car off) high speed pulls around 80A in-rush and 21A running. Low speed pulled 52A in-rush and 12.5A running.
    V3 model:
    Older model(s):
