Results 1 to 20 of 84
08-21-2004 #1
UPDATE 4/28/05 My engine is ALIVE!!!!! It runs again!!!!!
Well as we all know I have been having some great luck this year with everything on my car. Unfortunatly the good luck is over and the bad luck season has begun.
On my way home from Woodward I head a loud knock that repeated about 3 times so I instantly pulled over. I turned it off and started it back up. The knock persisted. I bowed my head and just about cried.
I waited about 5 minutes started it again and it seemed to disappear. I drove all the way home and the engine is squeling pretty bad. I assumed it was a rod bearing or main bearing.
I drained the oil and didnt see any metal shavings. Tired and depressed I decided to come in for the night and ask for suggestions. Tomorrow I will disconnect the belts to the alternator and waterpump in desperate hope that its just that. If not what is the quickest way to tell if its a main or rod bearing? Just drop the pan? If anyone would like a sound clip of the horrible noise I can do that if it helps.
