    Results 21 to 40 of 46
    1. #21
      Dayton, Ohio
      Quote Originally Posted by meenaggie
      Has anyone used the smooth firewall piece from Direct Sheetmetal? All the way at the bottom of this link . . . http://www.directsheetmetal.net/pages/chevy.html
      Saw this piece advertised in Chevy Rumble. Looks like a good start for a DIYer. Retail price is $420 on page 4 of their pricelist - http://www.directsheetmetal.net/grap.../PRICE%204.pdf
      Who would spend $420 on a piece of sheetmetal? I used 16 gauge scrapyard sheetmetal and the cost was only $12.
      Jeff
      http://www.kodakgallery.com/67rscamaro
    2. #22
      Quote Originally Posted by John510
      Hotrdbldr,
      How much do they run?
      won't know exactely until i get order is finished, but should be around the 140 dollar mark plus s/h.
    3. #23
      The Netherlands
      Country Flag: Netherlands
      I glued mine... see my page for explanation and pics
      www.pro-touring.nl
      pages 37, 38 and 39
      Martin
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
    4. #24
      Stuyvesant, NY
      I did mine with a piece of polished stainless steel. Made a cardboard templete and cut it out to fit.
    5. #25
      May 2008
      Mesquite Texas
      Now that is cool!
      Where did you find the polished stainless?
    6. #26
      smooth firewall
      Mikescustomcars.com has them and their are a fewto pick from. Go to his pro touring section, he has them listed.
    7. #27
      May 2008
      Mesquite Texas
      Thanks!
    8. #28
      Mountain View, CA
      So if one were to use the DSE "fill plate" what covers the portion where the blower sits?
      True T.
      My blog
    9. #29
      Miami
      I used the DSE on mine. Then had the body shop massage it..
    10. #30
      Rural Retreat,VA
      Here's mine, I used the replacement solid lower firewall.
      Keith
    11. #31
      Mountain View, CA
      So...just cut - weld in a circular patch for the blower hole?
      True T.
      My blog
    12. #32
      Miami
      are you running a factory a/c or aftermarket? This is from the DSE website " Our exclusive Detroit Speed & Engineering firewall fill plate is an excellent way to smooth your firewall when installing an aftermarket air conditioning system such as Vintage Air. Our panel smoothes the passenger side firewall, while retaining the stock cowl to firewall seam. The weld-in panel is made of 18-guage steel and has a rolled edge. It comes complete with installation instructions and is stamped with pride in the USA."
    13. #33
      Mountain View, CA
      I'll be running the Vintage Air "heat only" unit. The DSE panel, if I'm not mistaken, does not extend outboard to cover the blower hole. Am I wrong on that?
      True T.
      My blog
    14. #34
      Rural Retreat,VA
      Quote Originally Posted by Damn True
      Thats what I did, It's covered up by the fender.... I left the factory top seam.
      Keith
    15. #35
      Dec 2007
      British Columbia, Canada
      Here's how I did mine, really didn't take that long to do at all. I used some 18 guage sheet metal that I bought years ago to replace the floors in a Blazer build up that I did.
      Passenger side
      Driver's side
    16. #36
      Stuyvesant, NY
      Quote Originally Posted by 1BADRS
      Now that is cool!
      Sorry it took so long to respond. I never got an E-mail about it.
      Any shop that sells steel can get it. I like it. You cut it out put it on then your done.
    17. #37
      May 2008
      Mesquite Texas
      Ditto that. I have the DSE plate, it does not cover the blower hole, nor do I want it too.
      Going to use the hole to route my ac lines.
      I Drive a black escalade on http://www.68camaroproject.com
    18. #38
      Mountain View, CA
      Why are running AC lines to a heat only Vintage Air unit?
      True T.
      My blog
    19. #39
      May 2008
      Mesquite Texas
      Im running a full unit...not just heat...
    20. #40
      Castro Valley, CA
      You guys are probably wondering how mine came out after all these months. Well its smooth as glass now. Took a piece of 16ga and covered up the old one (that way I know where to put the holes).
      Used a piece of cardboard for the template. Welded all the way across the top and bottom.
      John S.
      68 "Bloodline" Camaro in assembly...
      Speedtech Sub, Alston G-Billet/Fab 9 rear, Ridetech coil overs, Moser axles, Fesler 19's, Lots of Anvil parts,Twin tubo LS3/T56, Carbon fiber manifold, and the list goes on and on..........
