Results 1 to 10 of 10
03-12-2008 #1
WTF!!! DSE 3" Drop Springs = NO DROP!!!
OK...HELP! On my 68 Camaro I've had (in the last three weeks!);
1- Dana 60 on stock Multi's
2- 12 Bolt on stock Mono's w/ 1" lowering blocks
3- 12 Bolt on stock Multi's
4- 12 Bolt on DSE 3" drop Multi's...
Guess which gave me the HIGHEST ride hight? The DSE's! Same shackle length, same 12 bolt, same car. Why so high? It now sits an inch higher than the other multi's, and two inches higher than the mono's.
There is NO WAY that stock would be 3" taller than with the DSE's installed...
HELP!!!!
Thanks in advance...
Jim Light
Owner/President, GGC Enterprises
71 Camaro RS, 383 Vortech Blown, TKO600, 9" w/3.55's, Wilwood Brakes, 17"f/18"r.
Under Construction:
68 Camaro RS, 496 BBC D1SC Blown, T-56, 12-Bolt Posi w/4.56's, C5 Brakes, HRE 545R's 17"f/18"r, G-West uppers and Sway-Bar, AFX Spindles, Del-a-lum's, Lee 12.7 Steering Box, Bilstein Shocks, and DSE 3" Drop Rear Multi Leaf Kit w/Koni's.
Other Cars:
69 Camaro RS w/355 & 6-71(drag set-up), 07 Velocity Yellow Z06, 06 Magnum SRT-8, 69/74 Nova ProStreet w/468 & 8-71, 03 Mercedes CL500, 04 HD 3500 Dually
03-12-2008 #2Registered User- Join Date
- Apr 2006
- 1,027
have front spring bolt loose, and well as both side of shacckle loose, let car down onto the ground, then tq to correct specs, if you tighten these up while on a lift or other, it will cause susp bind and not sit like it should, i have never heard a complaint on dse 3 inch drop springs
03-12-2008 #3Also, how worn or used are the other springs you used? Keep in mind the DSE springs will settle. Do like hotrdbldr says and put some weight in the back.
Camaro Convertible Build Pics - http://s447.photobucket.com/albums/qq198/rob07002/
www.musclerides.com
Rob Stevens
03-12-2008 #4The DSE 3 inch rears only sit around a 1/4 inch lower than Hotckiss 2 inch drop. On the same car, even after letting it sit with sand bags in the trunk for a few months. So much for advertised sizes.
03-12-2008 #5Jake is right on. I did the exact same thing when tightening the springs on my car. You can always add a 1" block if they still are not where you want them.
good luck
03-12-2008 #6
