    Results 1 to 20 of 31
      Eastern Virginia
      1 3/4" G body headers?
      Who makes them that don't go outside the frame rails & that fit good with motor in stock location & WITH AC?
      Scot
      86 Monte SS
      Woodbine, MD
      all I can tell you is that Dynatech make some 1 5/8" headers that fit well and install really easy. I believe they are pn: 21900 and are called the circle track headers.
      Eastern Virginia
      I already have Hooker 1 5/8" on it. Looking for bigger that fit.
      Scot
      86 Monte SS
      Eastern Virginia
      Supposedly Hedman's 65218 are 1 3/4" & fit. BUT the question is, will they fit with a wide sump road race oil pan.....
      Scot
      86 Monte SS
      Nov 2000
      O-town
      I bought Hedmans for my friends 78 Elky, I think that one tube still ran outside the frame, I can take a couple pics and send to you,
      Eastern Virginia
      Here is a pic that was sent to me, these are Hedman 65219 1-7/8" primaries. Can only see pass side, but I would assume if it doesn't go outside the frame, that the drivers side wouldn't either.
      Scot
      86 Monte SS
      Will those fit with AC? I've found lots that will fit.. but not with AC.
      The Gutless Cutlass, is no more.
      '73 Chevy C10, Low with lots of GO!!!!
      Eastern Virginia
      According to the guy that sent me the pic they will. I will call Headman & find out.
      Scot
      86 Monte SS
      Eastern Virginia
      I called them direct & he said that the oil pan width cannot be much more than stock or it will hit & that the AC box on the firewall had to go. :-(
      Fart! I thought I found one that would work for me.
      Scot
      86 Monte SS
      Nov 2000
      O-town
      The orig. headers he put on in the 80s, one tube went outside the frame rail, the new ones are fora A/C car, 1 5/8 tubes I think,
      Eastern Virginia
      Yeah I have seen all kinds of 1 5/8 ones that all fit inside the frame rails. I have a set of Hooker ones now.
      Scot
      86 Monte SS
      Woodbine, MD
      Quote Originally Posted by Samckitt
      if those fit with a stock oil pan and no a/c box...then those are my next headers!!!!!!! Thanks for the info...we monte owners need to stick together!!
      Eastern Virginia
      Yes those will fit with NO A/C box & with stock oil pan. I want them too, but won't work for me. Those pictured are 1 7/8" primaries. Hedman P/N 65218 are the 1 3/4".
      Let me know if you get them because I am curious what width pan will actually fit.
      Has anyone modified the factory G body AC box to make room for headers? PITA?
      Scot
      86 Monte SS
      Woodbine, MD
      i tried to modify my old a/c box to fit...but ended up just taking it out. I bought a non a/c heater box but it was all busted up. I plan on getting those 1 7/8 primary headers...do you think they will make the car a lil bit more potent??
      Eastern Virginia
      Quote Originally Posted by SicMonte
      Dunno. Remind me, what motor you have? For some reason I have 383 in my head.
      I read on another forum that I can get headers from Shoenfeld in 1 3/4" with a 3" collector & with flanges for the fastburn heads (D port shape). Their notes on them say may not fit with some kickout oil pans. So I need to call them & find out what width pan I can use.
      Scot
      86 Monte SS
      Clinton, MS
      1 7/8 is way too big for the street, Unless you are running at 7000 rpm all of the time. In fact you will probably lose alot of low speed torque. 1 3/4 is more than plenty for a street motor.
      the motor in the pic has 1 7/8th..... I think thats Mark's old motor IIRC... that motor was pretty much for straight out drags... 9 second car...
      He's looking for 1 3/4...
      Go buy some tubing and make a set dude.... seems to be the easy way out... =/.
      Jan 2010
      Houston,TX
      First post and it's a super bump. Did you ever find what you were looking for? I'm in the same market myself.
      Hedman husler 65218, I even still have AC
      http://www.montecarloss.com/communit...=744947&page=4
      1985 Monte Carlo SS- 224/228 cammed 5.3/4L80E/17x9.5 Budnik Tiller 5s/BFG Comp T/As
      2007 2500HD Silverado CCSB Duramax- 18" KMC HOSS, 285s
      2006 Corvette Coupe- Black/LS2/M6/3LT/Corsa/Callaway MP112/Nitto Invos SOLD
      2002 Sierra Denali Quadrateer-
      SOLD
      Eastern Virginia
      Quote Originally Posted by Mudweizer View Post
      I am still running 1 5/8" Hooker full length ones.
      Scot
      86 Monte SS
