Results 21 to 31 of 31
Thread: Effects of wheel/tire weight
12-05-2009 #21Registered User
- Dec 2007
- michigan
- 370
Holy resurrection batman!
The best visual aid I have ever seen to explain it is this. Take a hammer, hold your hand as close as you can next to the head of the hammer and rotate your wrist. It will spin very easy. Then place your hand farther away from the head of the hammer and try to rotate it. The farther you move your have away, the harder it is to spin. No change in mass, but a huge change in the amount of power it takes to rotate it. This also applies to stopping it as well.
So, for example, if you have a wheel that is 30 lbs, but most of its weight is near the center, it will spin easier than a 20lb wheel that has most of its weight on the out edge. So its not just about total weight, but also where the majority of the mass is located.
Then multiply that by 4, and you see how easily a larger dia wheel can affect things.
2005 CBR 1000RR..."mostly stock".
1968 camaro... "in the works".
