09-26-2007 #1
700R4: TCI Constant pressure Valve body
I was hoping I could get some input from you guys on a fairly new product that's available for the 700R4. It's a constant pressure valve body from TCI that provides 200 psi of line pressure no matter if the TV cable is mis-adjusted. You still use the TV cable to run your shift points, downshifts, etc., but the risk of burning up your trans is supposed to be eliminated. Anyone have any insight on TCI's solution for this problem? Pro's, Con's?
http://store.summitracing.com/egnsea...5&autoview=sku
My 700R4 is now slipping, but there has been no debris in the fluid and it has been working decently in this car for probably nearly 10K miles. Despite my best efforts to reinstall the TV cable properly after this latest round of restoration, I'm confident that the TV cable still isn't adjusted properly.
Is it reasonable to think that the additional line pressure created by the constant pressure valve body would stop the trans from slipping, or am I most likely guaranteed to be needing a trans rebuild (which I'd rather not do). For clarification: the trans isn't blown yet, I just can't give it much throttle without it slipping, acts like the line pressure isn't building along with throttle. But still no debris or burnt fluid, so it doesn't look, from that perspective, like the trans is hurt. (I should have gotten a 4l60!!! but this was done too many years ago)
Thanks for your inputJeff K.
69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
09-26-2007 #2
I'm curious as well. They're so new I wonder if anyone has experience with them yet?
09-27-2007 #3
(Sound of crickets chirping)
10-01-2007 #4
ttt
If no input on the new TCI valve body, which is understandable, anyone have any opinions on a good transmission builder in AZ?Jeff K.
10-05-2007 #5Registered User
- Dec 2006
- 12
Couple of things...
If it is slipping it needs going through. The constant pressure valve body won't reverse the damage you have already done to the clutches.
The constant pressure valve body sounds like another baind aid. The 700 has many charms but many well known flaws. The 3-4 clutches don't have an exceptionally long life even with stock setups.
This thing from TCI makes it sound like it solves all your problems but then you get issues with pump wear and added strain and hp loss for running the pump at 200psi all the time just to fix something that should be addressed with a proper cable adjustment. You can do something similar by just locking the TV valve down and running max pressure, which some kits do with the manual valve bodies. Not great for longevity.
My two cents is that it is not that hard to adjust the tv cable correctly. Do it right and you have no need for the TCI valve body.
10-26-2007 #6Registered User
- Aug 2004
- Texas
- 254
