    Procharged ZZ383?
    Will this engine survive with 6-8psi?
    All opinions are welcome.
    Are you smellin what I'm steppin in?
    http://www.fquick.com/ertoys
    Aug 2003
    NO, not without replacing pistons. It will explode with 2LBS boost if you do not change them. Otherwise is has good parts and can easily make a 600HP package, but you will need to do pistons and a major rebalance of the rotating assembly as the forged pistons are much heavier then your Hyper Explosive pistons.
    Quote Originally Posted by ProdigyCustoms
    x2
    its best(read cheaper) to do it right the first time
    Thank you both for the info, I truly appreciate it.
