Results 41 to 47 of 47
Thread: Anyone have regrets of going LSX
07-18-2007 #41
Don't look at the LS1 swap for just one particular thing like mileage or reliability.
Look at the swap as a completely new platform. Just to name some examples, the motor is lighter, more fuel efficient, is of superior reliability and design, has a long block that will handle over 1000 hp with a simple rod and piston swap, has the best fuel injection on the market that comes standard(not a $3000 upgrade), does not leak oil, already comes with an aluminum tall deck spread pan "Rocket block" from the factory, has heads that flow better then most ported SBC heads, has the ultimate COP ignition that supports 1500 hp stock, does not need so many upgrades to make good power, etc.
These are just a few reasons you should look into LSX and not look back. Do not look at one particular reason, look at the whole picture.
I was die hard SBC, I even had the best SBC you could buy( 427" tall deck 18 degree "street" motor) I am glad I sold it and did the upgrade to the LS1!!
It's not that hard, weld a new snout on the torque converter (+3/8"), remove the oil pan and remove 2" of the sump to fir in most cars and straighten the sump tube with a torch, take a couple hours and make some motor mounts after the motor is mocked up, hook up any fuel pump that will supply 45-60 psi of pressure, Go to napa and find new radiator hoses, hook up power to the PCM harness, bolt on some new shiny headers, and turn the key.
All in all, that is not to bad. Complete cost will be aprox $3000 complete! I spent almost $3k on just a block for my last SBC.
It all depends on what you want and your particular situation at the time.Twin Turbo Ls1 '71 Chevelle
93 octane 1000 hp street car!!
