      Window crank stud too short for custom made panels
      Hey,
      I am in the process of making some custom door panels for my 69 camaro, but ran into a little problem. The panels I am making are thicker than the original ones so when I go to put the original door crank on it, it doesnt have enough length to go on the stud without hacking up the surrounding area. Does a company sell an attachement to go on the window crank stud to lenghten them? Any info would be greatly appreciated.
      Toofun
      Mark
      Aug 2003
      You can buy the correct regualtors from Camaro vendors. An extension, I am not sure.
      Aug 2001
      Wilton, CA. (Sacramento)
      How much too short are they Mark? If you're using the standard window regulators the deluxe versions were a 1/2" or so longer.
      Jody
      Jul 2003
      Anaheim Hills, CA
      Power Windows maybe??
      1968 Track Rat Camaro:
      Thought of that
      Yea thought of that but power windows can be expensive once you get the kits that are available for the fronts and rears. Look Cool though. I also thought of cutting and welding a filler piece in between. Just thought if I could go about it an easier way I would. The deluxe studs may be longer and could probably work better but where to I get them and how do I install them?
      MARK
      TOOFUN
      CHICAGO SUBURBS
      Regulators
      I used standard regulator with deluxe door panels. I cut the ends off the stock ones and drilled tapped the ends. I used ends from another regulator but you could just put a spacer. After I knew it worked I beveled the pieces and welded it all together. The reulators come apart to weld. Frank
