    Results 1 to 9 of 9
      Which Years LS1 Rear Brakes Fit a First Gen Camaro
      I've seen the articles on 93-97 rear disks, but how about 98 and up? Can these fit as well?
      Apr 2004
      OKC, OK
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Apr 2004
      OKC, OK
      Forgot to add this is for a third gen but should apply to your first gen. Also you will need to run two right side caliper brackets unless you have moved the shocks I believe. Ebrake setup is different as well. Hopefully someone else will chime in and finish filling in the blanks.
      Mike
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Bedford TX
      you can use 98 or newer but then you still have the drum style e-brake, I didnt really like that set up so I went with 97 and older the set I used came with the e-brake cables and I got them to work with a little braket fabbing on a 68 camaro
      Justin, 68 Camaro Update:5 speed is in and neighbors are pissed!
      OK, thanks, guys.
      I will probably go with whatever I happen to find first, unless there is any issues with the newer style and the mini drum e-brake.
      My wife and I spent yesterday morning at the Junk Yard pulling out an 8.5 10 bolt housing from a 73 Nova. I couldn't find a 12 bolt and I'm going the low buck route until we have a bigger garage and I can fab the mounts for something more trick, like an IRS.
      It's nice to have a wife that will get her hands dirty turn the wrenches with ya!
      Bedford TX
      I got my rear brakes from a salvage in florida on e-bay went to there website and they were 25$ cheaper If I can find the name Ill post it in here It was 225 with shipping to Dallas Included everything bolts brackets, cables, and lines
      Oakland CA
      hell id love that website to please....
      :3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
      1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
      Bedford TX
      Here is that web page sorry it took so long It wouldnt ever come up in the search now I know why there site was down. The kit I bought was the 150$ 97 and older set. I did buy new rotors for it at auto zone just so they were new looking.
      http://www.tacreationsusa.com/suspensi.htm
      Tracy, CA
      I have installed LS1 (LS1 is 98-up F-Body) Rear discs on a 69 camaro. The fab work was mostly simple, to modify the driver's side backing plate/caliper mount to put the driver's side caliper forward of the rear axle.
      Photos at the link below
      _________________________________________
      1969 Camaro, Tom Nelson 434 TT / T56 / Wayne Due C5 / DSE Quadralink / And a bunch of other stuff....
      http://www.lateral-g.net/forums/show...t=12743&page=5
      Pictures of my cars:
      http://community.webshots.com/user/rswhite
