Results 21 to 40 of 91
07-21-2006 #21
Steve, in my opinion, stock Holley carburetors trick people into thinking they know how to tune any carburetor. The reality is that stock Holleys don't run as well as others, but they don't run well equally on most motors, which equates to very little tuning time until it's as good as it's going to get. Yes, Demons are extremely touchy, but if you know what you're doing, you'll be glad they are. IE 1/8 turn on the idle mixture screws actually does something! They are a lot of work to get right though.
If you ever want to see how a carburetor should run, have one built professionally. Then you'll understand how bad stock Holleys really are.
-Matt
07-21-2006 #22Matt, I tried the 4.5 power valve and still have the surging. Only now instead of the surge stopping when vacuum reaches 6.5 (as with the 6.5 power valve), it now stops surging when vacuum reads 4.5. So the surging stops when the power valve begins opening. I can only assume if I installed a 10.5 power valve the surge would clear up at the 10.5 vacuum mark (for example). I've considered once again plugging the power valve completely and jumping from 85 to 95 jets in the primary to compensate for the now plugged power valve.
07-21-2006 #23
07-21-2006 #24Leave everything the same, but go up 10 jet sizes front and rear. This sucks long distance.
-Matt
07-21-2006 #25Originally Posted by Matt@Lateral Dynamics
So leave the power valve at a 4.5 and go 85->95 primary and 93->103 secondary? I don't think I have anything bigger than a 99 jet.
It may be a while before I can test this change considering that I broke an axle tonight at the track. I guess the 572 was too much for the stock 12-bolt axles. I did click off three runs in the low to mid 7.60s though (1/8 mile).
07-21-2006 #26
