Results 1 to 10 of 10
Thread: end play axels
04-18-2006 #1Starting The Transformation
- Sep 2005
- new zealand
- 113
end play axels
hi everyone i just removed the wheels on my car and noticed the axles with a unusual amount of endplay in and out probablt 3-4mm which dosent sound much but makes abit of a thud when moved in and out thanks hiwayman
04-19-2006 #2Registered User
- Mar 2005
- Colorado
- 94
I just asked this question on another board. Some people said not to worry about it that their car had a ton of endplay and had for years. I was told that is caused usually by how much wear the clutches of a my posi have. Are you using a posi? The only solution I have found is that people buy valve spring shims, because they are almost the indentical size and are hardened steel. They can be easily cut to work with the c-clip and take up space in the grove on the axle and reduce your endplay.
68 Camaro
LS2 6speed
Complete Hotchkis front and rear suspension, Global west SFC, 3rd gen steering box, C5 front rear discs w/ 4th gen booster and MC. 8.5" posi rearend with 30 Spline 12 bolt axles.
04-19-2006 #3Starting The Transformation
- Sep 2005
- new zealand
- 113
hey midnight unfortuatly the diff etc is all brand new going to pull the axels take to shop for a diagnose, how much endplay did you have?thanks hiwayman
