    Results 1 to 1 of 1
      Dec 2021
      PNW
      67-69 Camaro/Firebird & 68-74 Nova Sub Frame w/Chassisworks suspension + big brakes
      I have a media blasted and painted stock sub frame from a 69 Camaro fitted with Chris Alston's Chassisworks suspension and Wilwood big brakes. There is a Trans crossmember for use with Tremec/Richmond/700R which is from Chassisworks. As well as adjustable black powder coat LS engine mount set from Chassisworks. There is also a Sweet mfg steering box 12:1. All with zero miles. Im thinking of going with an aftermarket sub frame so I can fit bigger wheels up front. I have paperwork and receipts. Some parts arent shown in the pics. Im in the Portland OR metro area. Id prefer to sell the whole lot intact. If I decide to break it up, the suspension kit will need to sell first before the brake kit. Also this kit requires 17" or larger rims.
      Price for everything: Paid $7851.10 Asking $5500.
      Price for Frame w/ suspension kit, trans crossmember, steering box, engine mounts: Paid $6035.40 Asking 4200.
      Suspension includes:
      Tubular upper and lower control arms
      Varishock double adjustable coilovers w/pivotball Q2
      500lb coil over springs powder coat silver
      solid sway bar 1" diameter w/ billet alum urethane pivot blocks & end links
      bumpsteer set, inner tierods, idler, billet sleeves
      Billet aluminum 2" drop spindles w/ billet aluminum steering arms Z28 quick ratio
      Wilwood big brake kit:
      Black 6 piston forged narrow super lite calipers with pads
      13" Spec 37 competition vented rotors
      *I also have a Wilwood master cylinder, flexline kit, proportioning valve, and body mount bushings available.Name:  20210826_112112.jpg
Size:  375.9 KBName:  008.jpg
Size:  323.7 KBName:  IMG_0698.jpg
Size:  125.0 KBName:  IMG_0700.jpg
Size:  169.3 KBName:  IMG_0702.jpg
Size:  88.6 KBName:  IMG_0703.jpg
Size:  135.9 KBName:  IMG_0706.jpg
    Tags for this Thread
