    Results 1 to 18 of 18
      Jun 2025
      64 Impala ss - looking at going pro touring, need guidance
      Hey, I just picked up my dream car. It is a 1964 Impala SS 2 door hardtop 327. I am looking to go the pro touring route. My goal is for it to handle like a sports car but keep its original essence and swagger. Thinking staggered 20's, maybe 20/22 depending. I do not want to cut the car up for wheels to fit, I do not want it to rub etc. I have an Chevy OBS with approx 800hp and on air bags and it is nuts. This one i want to make it a cruiser that i can drive it and enjoy it and still keep up with modern sport cars. Bigger brakes, thinking some kind of coil over set up. Looks to have a lot of options out there. What have you guys used, what mistakes have you guys made? I feel like this is a huge step up from my last build and if I built another obs I would spend a lot less since i already know what works well etc., so I am hoping some of you guys can bestow your wisdom on me as well.
      Name:  64impala dealer.jpg
      Des Moines, IA
      I would contact Boris Maryanovsky at Street Machinery.
      He deals with a lot of Impalas and can provide sound advice.
      https://streetmachinery.com/
      Mountain Springs, Texas
      I would think that the frame itself needs work. They were designed to articulate and rotate and that’s not what you want in a Protouring ride. I am sure there are solutions out there.
      Boris will be happy to sell you a Roadster shop chassis. He sells a lot of them.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Nov 2018
      I think a Gen4 6.2L/6L80E will make it a nice, efficient cruiser. The aluminum block will take weight off the nose as well, helping with handling. The two extra gears will let you play with the rear ratio to get a snappy takeoff while still pulling decent cruise mileage. I would suggest the 8 speed, but that only comes on the Gen5 engine and I just can't bring myself to recommend direct injection.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
      Jun 2025
      Not looking to engine swap and go as extreme as a frame swap, just want to make it feel tighter and keep its old school feel. Brake alittle better and just enjoy it
      Apr 2016
      Id check out the options from ridetech, they have the street grip kits or you could step up to coilovers. I would likely replace the steering box as well as the steering components.
      Beach Park IL
      That. Pick the parts from the ridetech catalog that fit your budget and skill set. Use a Borgeson steering box, you will have to change the radiator to clear the box. It's worth it. After that, desired wheel diameter determines brake diameter.
      Donny
      Harriman, Tennessee
      What?? Where in the world did you get that idea?
      Why do termites eat houses?
      Because they have
      Munchausen Syndrome.
      Oct 2018
      San Jose, CA
      Quote Originally Posted by ProTouring442 View Post
      I don't think the frames were designed to flex, but those frames most certainly do flex quite a bit.
      It's an X frame. Not really a very good design.
      I would think the best thing you could do is start from the frame up honestly.
      If you want a pro touring ride by any definition.
      If you just want a fun classic cruiser - that's a different matter.
      Start with what are your goals and build it accordingly.
      first call I would make is to one of these places:
      https://www.schwartzperformance.com/...cayne-chassis/
      https://roadstershop.com/product/196...-mount-options
      https://artmorrison.com/chassis/1959...rolet-chassis/
      Yes - I have owned one, a '63 set-up for drag racing. I fixed the chassis issue with a 8 point roll cage.
      But if I were building one as a pro-touring type ride I would not mess with anything on the stock frame period.
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
      I thought I read it but I can’t find it now so it must have been my early onset senility…
      Apologies for any misinformation.
      Don
      Harriman, Tennessee
      Don
      No worries! It was actually a pretty good frame for its time. For a modern Pro-Touring car, it definitely needs some assistance (or replacement).
      Because they have
      Harriman, Tennessee
      Quote Originally Posted by guys64impala View Post
      What's your budget?
      If high, an aftermarket frame would be your best bet.
      If lower, I would look at using the floor pans and frame from a Ford Crown Vic or 80s/90s Chevy Caprice and upgrade from there.
      Because they have
      Beach Park IL
      Using a 40 year old car to upgrade a 60 year old car is a choice, but not one I would make.
      Did you see where he said he doesn't even want to engine swap it?
      streetgrip, Steering box, Power Wilwoods, 18" wheels. Done.
      Donny
      Oct 2018
      San Jose, CA
      ya - it was designed with a 300hp cruiser in mind. Stuff a 500hp+ motor in there and things get very dicey. Totally fixable with a 8 point roll cage.
      But for a pro-touring car you want to handle and ride like a modern car, I would start over there before you start spending $ on making the stock suspension better. Suspension only works as well as the frame under it at the end of the day.
      Some factory frames are pretty decent and can be made very stiff with some minor re-inforcements (good example is 2nd Gen Camaro or an A body).
      Even the '65+ Impala frames are not bad. Early 60's X frame - not in that category. Sorry to break the news to you but it is what it is.
      2018 Colorado 4x4
      Harriman, Tennessee
      Quote Originally Posted by c4racer2 View Post
      I used to drag mine pretty regularly with a good 500hp and a ton of torque (bored and stroked 409 to 482). Never had an issue. Well, I blew a few differentials...
      I'm not saying modern frames aren't better, but the 1961-1970 X-frames weren't all that bad either.
      Because they have
      Harriman, Tennessee
      If he doesn't want to do an engine swap because of cost...
      Which is why I asked about budget.
      The B-body frame I mentioned has the same front suspension as the second gen F-body, and so is very eaily upgraded with larger brakes (12"), etc. The rear suspension isn't all that bad, but could be upgraded to a torque-arm at pretty low cost if the converging link 4-link isn't to his liking.
      The frame itself can be boxed and fully welded for little to no money.
      So all you have is the floor to swap, and since that would come on the very-inexpensive donor car...
      Because they have
      Beach Park IL
      Read post number five. He can accomplish those goals with simple and easy upgrades and you are recommending cutting two cars apart to merge them together in a *******ization that has very little net positive.
      Donny
      Harriman, Tennessee
      Actually, it would have a lot of net positives. Better suspension, stiffer frame, better room in the floors, more headroom, cheaper, etc., etc.. But it's all moot as de doesn't want to tackle such a thing (and I can certainly understand that!), but that's not what you challenged. You challenged the value of such a swap.
      Anyway, good discussion. Back to to the OP!
      Because they have
