    Page 2 of 2 FirstFirst 1 2
    Results 21 to 25 of 25
    1. #21
      Nov 2018
      They took long enough to respond. Anyone with a fan they can't use an ECM on and doesn't have its own built-in controller, DCC Controls is the way to go.
      brian
      [email protected]
      To:
      Vimes
      Fri, Jun 14 at 12:33 PM
      It will work on a brushed and brushless fan, it wont work on a fan with an internal pwm
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
    2. #22
      brian
      [email protected]
      To:
      Vimes
      You mean like this one that specifically states can’t be used with PWM controllers?
      https://www.summitracing.com/parts/pro-67035
      A brushless fan will still have a multiphase inverter and it’s going to get quite pissed off if you connect it to a DCC PWM controller. Perhaps DCC could supply details of brushless fans that work with their controller….
    3. #23
      For those who are interested here is some good information on how brushless DC motors operate and how they are controlled. It’s complicated….
      https://www.renesas.com/us/en/suppor...r-01-overview#
      https://www.renesas.com/us/en/suppor...2-inverter-pmw
    4. #24
      Newbury Park, CA
      The brushless fans that are three wire (bat+, bat-, pwm signal input) cannot be used with the DCC (or PSM/vaporworx) brush-type controller. Basically any brushless fan motor that needs a PWM control signal.
      For brushless fans that do not have the logic built in (two wire) there is a very good chance that the DCC controller will work well. It does work on other similar brushless motors such as those used for water pumps. A bit of experimentation would be needed but with a high likelihood of success.
      But, if given a choice, the OEM or Spal brushless fans with built-in logic would be my first choice. They are worlds better than the aftermarket 12v-on brushless fans. Control can be done with an OEM ECM, many aftermarket ECM's (Holley), or a DCC/PSM/VaporWorx stand-alone brushless fan controller.
    5. #25
      Nov 2018
      Ehh, that was what they sent me, that's all I can do. I moved on to ECM control years ago so can't say one way or the other.
      2021 Durango R/T
      2005 Dakota beater
