      Aug 2021
      LT4/8L90 into 1966 C10
      Howdy folks ! My second visit, no response on the first so thanks in advance for your patience!
      I bought a connect and cruise package that has engine , trans, ECU
      and TCM . (Think the acronyms are correct!) Anyone out there done
      that ? Looking for guidance on cutting the floor and or firewall for the
      8 speed , Headers ? Any other issues you care to share? Thanks much
      Any help would be appreciated
      Jan 2024
      Gainesville, Ga
      Unfortunately this place is fairly dead. You'll likely have better chances with advice or finding others that have done that on one of the many C10 Facebook pages.
      Jun 2021
      I put an LT4 and 8L90 in my 85 gmc. Being a connect and cruise im guessing you will be very happy with the tune and trans tune. I have a seperate PSI conversion harness with a 2018 Z06 computer.
      You will have to cut the trans tunnel, its a much larger transmission. Depending on how low you go, you may have to allow for the driveshaft. I don't think you should need to push back the firewall.
      I mentioned the tune because my engine and trans tune is still not where I want it. Its really close but the GM tune should work great.
      Cornettsville, ky
      67-72gmtrucks is the best full size chevy forum
      May 2023
      Quote Originally Posted by hddoktr5 View Post
      I recently used Vehicle Shipping Advisor for heavy equipment transport and couldn't be happier. Their service was professional, efficient, and cost-effective. The team managed everything seamlessly from pickup to delivery. My machinery arrived safely and on time. Highly recommend their reliable and hassle-free transportation solutions! Check out their services and heavy equipment transport cost
      The connect and cruise package is a great choice, offering a comprehensive solution with engine, transmission, ECU, and TCM. For installation, cutting the floor or firewall for the 8-speed transmission can be a meticulous task. It’s recommended to follow a detailed guide or video tutorial specific to your vehicle model. As for headers, ensure you have the right tools and follow the manufacturer’s instructions closely. If you encounter any issues, forums and videos from experienced builders can be invaluable resources. Good luck with your project!
