Results 1 to 11 of 11
01-14-2023 #1
68 Camaro Ridetech coil over ride height
Seeking advise from you guys. I have a 68 Camaro with a ridetech front and rear coil over set up. The front tires are rubbing and I want to raise the front end about an inch. I have run the preload up probably farther than recommended. See photos. Tires are 245 40 18. Should I try and find a different spring at this point?
The rear also rub going down my driveway on an angle and tore up the quarter lip. I have also run up the preload on those. Can I move the shock mount up one to the mono leaf holes or do I need new spring on the rear too? See photos.
