    Results 1 to 11 of 11
      Jul 2012
      Louisiana
      corvette filter regulator plumbing
      for the gurus which one of the connections is the supply and which is return. i've done many searches and see both as supply and return. i assumed the middle is supply but now not sure. HELP!!!!?
      Apr 2007
      New Jersey
      Doug L.
      68 RS/SS Conv. DSE/Ridetech and LSA/T56 rebuild in progress
      67 RS Coupe LS2/T56 named "NutKse"
      Jul 2012
      Louisiana
      Thanks, got it. The offset one, and the larger of the 2.
      Quote Originally Posted by Poncho72 View Post
      Make sure that the filter/regulator you are using is an AC Delco or WIX part.
      Jul 2012
      Louisiana
      one i have is from Summit. What issues would i have if not Wix or AC Delco?
      Jul 2012
      Louisiana
      this one: SUM-230151. should i not use it? i've read product reviews on Wix, ac delco, & Summit brand, and all have about the same ratings....4.5 stars and about the same failure rate of either not regulating at all or providing too much pressure. seems like i may need to consider a diff setup. thoughts? appears that the ac delco is made by WIX as they have the 33737 part # etched on the unit.
      I would not use it. There have been quite a few fuel pressure issues related to these no name regulators. Summit buys the cheapest part they can find….
      Jul 2012
      Louisiana
      Noted Don, see my edit of last post. what direction should i go if not this setup?
      If I was all set up for it I would use the Wix FPR.
      I haven't used one in years since pretty much everything I build now has a fifth gen fuel module and vaporworx controller.
      I've had good luck with the C5 FFR. But I've only used the Wix or Delco FFR.
      Years ago a bought C5 FFR "kit" from Summit. The filter leaked on the outlet side. I spoke to Summit and they sent me a real AC Delco or Wix I forget. They didn't want the old one back so I tossed it in the bin.
      Newbury Park, CA
      As Andrew and Don have mentioned, use the Wix or ACDELCO/GM part.
      We've tested a bunch of them, and there is a difference.
