Results 1 to 9 of 9
09-17-2022 #1
68 Camaro gas pedal and LS3...will not open throttle all the way
I have the 6 cylinder factory pedal assembly installed in my 68 Camaro, and I am in the process of installing an LS3 with Fitech fuel system. I also am using a Lokar 36" cable.
The issue is that I can not get the pedal to open the throttle all the way. The travel of the pedal only opens the throttle about a third of the way.
Any suggestions other than just installing a Lokar or Billet Specialties pedal assembly.
09-25-2022 #2
I run the 6 cyl. pedal on my 69 with a LoKar cable to a drive by cable throttle body and have no issues, which throttle body are you using and what bracket on the intake are you using if one?
09-26-2022 #3
My pedal only moves enough to open the throttle about half way.
- - - Updated - - -
09-27-2022 #4
