    Results 1 to 3 of 3
      Jun 2009
      From Wasilla, AK. Now portland, OR
      8.5 rear and springs
      So i am replacing my rear setup on my 69 camaro. pulled the rear leaf springs and rear axle out to put a 9 and 4 link set up in it. i need some help identifying the parts and value.
Size:  186.8 KB60" wm to wm. has 1243774on the left front lower ear. ja g237 2 on the right tube. b ar stamped on the right rear. h73 on right rear lower hear. i do know its a 8.5.
      the springs have a American flag sticker on them and 7 1/8 when measured from the ground.
Size:  374.5 KBName:  IMG_2320[1].jpg
Size:  340.9 KBName:  IMG_2321[1].jpg
      If you need any more pics please let me know.
      thanks
      1970 Elcamino ls3/t56, ricks/vaporworx, sc&c afx ,forgeline zx3, kore3 z51/ls1
      1969 Camaro ls1/t56, ricks/vaporworx, ride-tech,forgeline ga3,
      1996 civic the car that makes it all possible
      I can't tell from looking at it, but I know that stock 67-69 Camaro's came with the weaker 8.2" rear differential stock. However in 73-74 the Xbody Nova's came stock with the much stronger 8.5" and were a direct swap for first gen Camaro's. I'd confirm if it's the 8.2 or 8.5.
      Jun 2009
      Yes i am sure it is a 8.5 and not a 8.2. looks like it had upper mounts cast in to the housing that was cut off. also set up for multi leaf setup. what is a nova 8.5 worth? thanks
