    Results 1 to 12 of 12
      May 2014
      69 Mustang need help deciding which wheel to get???
      Been using these Magnum 500s for years. Every 69/70 Mustang has them at a Car Show.
      I’ve won many awards with these, but it’s now time to change for a more modern look.
      I want to go with 18s in back and 17s in front. Right now there’s 15x10 5.5bs rears & 15x7 4.5 bs in front. I’m switch to Wilwood 4 wheel disc and coil over in front. Still gonna use stock front & rear suspension.
      Can’t afford Forgeline etc… around $1000 a wheel.
      Looking at Billet Specialties or Weld.
      Which is your pick. Thank you!!Name:  88BFAB43-1091-4915-87A9-565BB8369A21.jpeg
Size:  213.0 KBName:  C0DF73CC-8535-4973-8D07-34AC88FE857C.jpeg
Size:  144.7 KBName:  E7903CF2-3321-4768-9F37-CE2D0EB08874.jpeg
Size:  217.2 KBName:  1898B837-5EEA-4F31-98D3-4F6837C279B7.jpeg
Size:  615.6 KBName:  F9900D07-0C50-456C-A45D-032186978B9B.jpeg
Size:  144.0 KBName:  6CB107E1-9C43-468F-97E0-33E451CECA8B.jpeg
Size:  133.0 KBName:  CA3F025F-7059-4F4D-BF2D-F6901477B52C.jpeg
Size:  279.4 KBName:  F6EE3A25-3767-48A0-AEB3-B5C6C9680525.jpeg
Size:  293.3 KBName:  205B8FCF-8C0F-472A-B9FB-B17CB714BC84.jpeg
      Jan 2011
      Jefferson City, MO
      I donk know if the available offsets would work, but think these would look bitchin'.
      Jan 2011
      Jefferson City, MO
      Hmmmm, the image wouldn't attach.
      May 2014
      Anybody out there????
      Mar 2015
      Baton Rouge, LA
      For the weld wheels I'd personally stick to the S71, but if you're willing to go up to $4k for a set of wheels I'd also look at forgestar and maybe BC forged monoblocks as well (I think they only make 18"+ though).
      Just North of NYC
      Your car looks very well integrated right now. I’m afraid if you put some modern pro-touring rims and thinner sidewalls it would jump out as a little inconsistent thematically. It would be the only thing from a different genre.
      Just my $0.02 of course. Beautiful car and color.
      I would go 18" all around. Maybe 245/40/18 front and 275/285/40/18 rear. The smaller front tire will give you a bit of rack.
      I think a set of polished Torque Thrust II's would look great. Some what retro.
      Pic of my 66 fastback.Name:  66 Mustang 1-01-06.JPG
Size:  318.0 KBName:  1966 Mustang 9.JPG
Size:  317.0 KBName:  66 Mustang 1-01-06.JPG
      - - - Updated - - -
      Sorry about the double pic post.
      Oh and you have a great looking Mustang.
      Nov 2018
      Everything looks good with a slotted mag, and it'll be period correct.
      http://www.americanracingwheelsinfo....t_Slot_Mag.htm
      Something to keep in mind with larger wheels is weight. Larger wheel means more metal with the rubber, and that metal gets heavy fast. Some of the 18s can hit 50lbs or more just for the wheel itself, then you need the tire on top of that. The extra weight will affect handling and may require that you beef up the suspension which was designed around 25 to 30lb combined wheel and tire weight.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
      Oct 2010
      SLC
      probably not your style but mini-lites look great IMO.
      I think they make a simar wheel in 17s.
      Zach
      Feb 2007
      Tinley Park, IL
      Quote Originally Posted by Zachalanche View Post
      I agree with this suggestion.
      https://www.etmags.com/lt_iii.html
      Name:  Screenshot 2022-05-24 191850.jpg
      Nick ~
      1969 Cutlass
      Sep 2012
      S81’s
      - - - Updated - - -
      apparently you’ve never picked up one of those weld wheels, the s81 are LiTe!
      - - - Updated - - -
      damn, those are awesome. What size?
      I will be trying to find a set in 17” for my Camaro this year
      Nov 2018
      Quote Originally Posted by Anthony k View Post
      ...apparently you’ve never picked up one of those weld wheels, the s81 are LiTe!
      r
      Well, I've not picked up EVERY wheel out there, but...
      I was looking into a set of 18in slotted mags for my project, and per US Mags the ones I wanted (think it was U101s) were 50lbs just for the wheel. Very disappointing, and I decided against them. That was when I was planning on a 3 link solid axle, but since I switched to a C5 front and rear suspension on Dobbertons, I'm up in the air on wheels. Got a cheap set of 18s for a Corvette for the build process, and they're 31lbs a wheel. But, now when I make wheel recommendations I'll usually include a "check the weight" warning.
      2021 Durango R/T
      2005 Dakota beater
