    Results 1 to 7 of 7
      Nov 2010
      orlando fl
      Accufab throttle body linkage with shaker 77ta
      So I hope I can accurately describe this for you guys! I am running a MP Holley terminator setup with an accufab 4150 throttle body …..but am wondering what I can do to modify the linkage so I can use my throttle cable on my northwind intake. With the shaker and drop base it needs to be in a traditional position much lower than this high thing that comes with the accufab. Anyone have any ideas? Thank you!
      Nov 2010
      orlando fl
      Bring back the answers to this forum!!!
      Dec 2011
      Toronto, Canada
      Cut the arm down , and build a dog house into the bottom of the air cleaner baseName:  20220128_165456.jpg
Size:  297.5 KBName:  20220128_165502.jpg
Size:  321.1 KBName:  20220128_165511.jpg
Size:  115.8 KBName:  20220128_165546.jpg
      Nov 2010
      orlando fl
      Thank you! Looks great do you have anymore pics of the underside of cleaner base? And where did you get that cable and attachment?
      Dec 2011
      Toronto, Canada
Size:  345.3 KBName:  20220129_114411.jpg
Size:  166.7 KBName:  20220129_114401.jpg
Size:  216.3 KBName:  20220129_114355.jpg
      The linkage is not a cable it as a heim joint I found at an industrial supply store not an automotive store, it is threaded on to a 1/4 inch mild steel rod I custom bent and cut a thread with a die to screw the heim joint on, to make my throttle linkage, I will look for a pic of the mini heim.
      Dec 2011
      Toronto, Canada
      I had to drill and tape the throttle body arm to match the threads on the heim
      Nov 2010
      orlando fl
      Quote Originally Posted by q67 View Post
      thanks man! Ima give that a shot
